Best oil?
Run the cheapest syn. that you can find (that's from a major player) and spend the difference on a quick burger meal while you wait.
As for weight, follow whatever Ford recommends for your vehicle.
Costco sells Mobil 1 for $26 for 6 quarts when it's on sale, but having used it in another vehicle (a Subaru), find that it seems to burn off quicker than other full synthetics. And I have found scare stories about people trashing bearings in turbo Subarus with Mobil 1. I have had great experiences with Valvoline Synpower full syn, as well as Pennzoil and Quaker State full synthetics in both my van and my other vehicles, but am pretty much back into syn blends or conventional oils--none of my engines are high performance motors.
If it's a brand new vehicle, there is a school of thought that you shouldn't switch over to full syn until 10k miles or so.
I ran my '02 E150 on Quaker State full syn for about 35k of its 120k miles and found no difference in consumption, gas mileage, etc as compared to Motorcraft syn blend. (I got 24 quarts of the stuf for a buck a quart--5W20.) The only justification I might make for full syn is in REALLY cold winter temperatures or really heavy duty use as in pulling a trailer or racing.
Use the weight that Ford recommends, which is 5W20. The mod motors need the lighter weight oils to get oil into the valvetrain ASAP.
There are scores of threads on FTE about oil, and if you want to be a real oil geek, go to bobistheoilguy.com and spend as much time as you want researching.
Also, I would recommend use Motorcraft oil filters. They have the bypass valve at the base of the can, and a silicone anti-drainback valve. Do not use Fram or other cheapo filters. I have heard valvetrain clatter using cheap oil filters meaning that the ADB valve lets the oil back into the pan. I have also had good luck with Purolator Pure 1 oil filters.
Good luck for many safe and trouble free miles in your van,
George
(Choose the viscosity.)
Motorcraft filters, I order 12 at a time:
There's a small savings on the filters, have paid upwards of $8 each for the NAPA Premium version.
Oil is the big savings plus it comes right to your door---no surly sales sheeple and all the driving etc normally required.
I order 3 or 4 of the 5 quart bottles each time; less packaging and much much more convenient all around IMHO.Keep in mind I change my oil ever 3 or 4K miles regardless the suggested intervals of longer life. Its a small price to pay for (hopefully) keeping a good running motor.
HTH
Amazon.com: Valvoline 782256 MaxLife SAE 5W-30 High Mileage Motor Oil - 5 Quart: Automotive
Amazon.com: Motorcraft FL820S Silicone Valve Oil Filter: Automotive
HTH
(The original oil spec for the BMW was 15W40 and I used a lot of Shell Rotella in it over the years--but I drive it very little and the 10W40 flows better on cold starts.)
For a newer van, I'd stick with the Motorcraft syn blend 5W20. My van has 120k miles on it and does great on the Motorcraft syn blend. Consumes less oil now than when it was new.
Like I said, you can research all you want, but the Motorcraft stuff is great and there is no question that it will maintain your warranty coverage. (I know that any oil and filter that can meet specs does not void your warranty, but if you do have an oil related engine failure, there is no question with the Motorcraft stuff in your motor.)
Good luck,
George
And lately I'm getting tired of buying full synthetic. Double the cost- for what? My van gets lots of miles, but operating temps are always normal, ...
It still drinks one quart every 1,000 miles whether it's full- or semi synthetic, or regular oil.
I'm about to start using Advance Auto 5W20...
Amsoil, Schaeffer, and Purple oils are niche products who have their "believers" and big sales hype. I am not into hype and never will be. They buy base stocks from one of the major oil mfrs. Amsoil is almost like a religion among its believers (and a pyramid scheme as well)... I call BS on 4 mpg increases with any oil. And I'd like to see real evidence of anyone in Florida or anywhere else that really killed a mod motor solely because they were running the recommended weight of oil. "They say" is not a compelling argument.
Peace out,
George
Changing oil in our vans is not a tough or overly expensive task whether we're doing it at 3 or 4K (me for example) or letting it go to 5 or 7.5 K, NOT me. Regardless how high quality an engine oil might be its still subject to all the same conditions and contaminants as any other type or brand. I have huge peace of mind and plenty of experience that proper oil for any particular engine, "frequent" changes of filter and oil leads to motor longevity.
Perhaps in systems not internal combustion full synthetics are a marvelous thing. I'm sure its never been proven or even discussed how more frequent oil changes are detrimental to an engine's life. I KNOW Amsoil et al probably have reams of facts, research and so on about their products---I still do believe its in my financial or reliability interest to let engine oil go so long before its changed, much like my BVD's!
Good ADB valves are important, probably more so than the type of oil you use, as most engine wear happens on startup. It's not like Motorcraft filters cost a lot--they are downright cheap.
George
Even if God made a Super Eternal engine oil, it's still gonna get dirty in our engines.
20,000+ mile oil changes are not reasonable for everyday people.
And I also call BS on 4mpg increase via different oil.
Increasing fuel efficiency can be done in two ways: reduce parasitic losses, or add power while sustaining fuel useage.
- Oil cant make the explosions better inside the engine.
- And even an A/C compressor doesn't cost 4mpg. No way is magic oil able to free up parasitic losses exceeding a mechanical freon pump.
Peace out,
George
