How To: Install OEM Remote Start
Old 01-26-2017, 07:37 PM
fastback89's Avatar
fastback89
fastback89 is offline
I just recently installed the plug and play kit, which included 2 keys and a small harness with the antenna. I am impressed with the range, at least 200 feet and possibly more. The range may even be farther than the wifes new jeep GCH that came factory with remote start.
Old 01-27-2017, 08:28 PM
Crownman2014's Avatar
Crownman2014
Crownman2014 is offline
I just installed the same OEM kit and can concur with the decent range. With line of sight it's around 200 feet. Personally, I wouldn't remote start it if I was any further away anyway.
Old 02-24-2017, 12:30 PM
hammer65's Avatar
hammer65
hammer65 is offline
I just got my remote start working this week. With my refurbished keys and no antenna, It will work out to about 30' so far.
Old 02-28-2017, 05:47 AM
hammer65's Avatar
hammer65
hammer65 is offline
I did my son's truck this weekend, and he said it worked well at his house, (about 20')until his wife pulled in between the house and the truck. Then it didn't work. He is going to keep testing. I suggested he get a new battery and try that. These new keys may not have good batteries.
Old 02-28-2017, 07:17 AM
paintballdude05's Avatar
paintballdude05
paintballdude05 is offline
The RS is limited to the same range as you had with the RKE before the mod. The antenna and extension harness are fairly cheap, why not just finish the mod with those?
Old 03-07-2017, 12:01 PM
Nododges's Avatar
Nododges
Nododges is offline
This is a great post, but, I followed your video almost to the letter. I put my receiver beghind the glove box. I did all the changes with Forscan, but all I are the lights flashing when I try to remote start. The hood switch is there, it has no cel or codes. Any ideas?
Old 03-07-2017, 12:09 PM
paintballdude05
Are you going and doing the right remote start procedure? lock, start, start?
Old 03-07-2017, 12:44 PM
hammer65's Avatar
hammer65
hammer65 is offline
Where did you get your key, and did it program correctly?
Old 03-07-2017, 03:25 PM
Nododges's Avatar
Nododges
Nododges is offline
The keys came from Ford and were programmed by the dealer. Yes, I am following the correct start procedure, but all I get is two flashes from the parking lights.
Old 03-07-2017, 07:44 PM
fastback89's Avatar
fastback89
It sounds like your issue may be with BCM activation. I would go back in FORscan and look at the letters to make sure they are correct.
Old 03-08-2017, 07:22 AM
Nododges's Avatar
Nododges
Nododges is offline
I have checked and rechecked in the Forscan and I can't see anything wrong. The dealer made the changes to the bcm, but the text is all correct. Am I missing something?
Old 03-08-2017, 12:37 PM
KSUfan86's Avatar
KSUfan86
KSUfan86 is offline
I had the same issue, lights flash but no start. Discovered a switch for the hood was not installed and the system thought the hood was open. Once I reinstalled the switch, I could remote start the engine.
Curt's05
2009 - 2014 F150
28
06-13-2022 06:14 PM
Stephen Fruscillo
2009 - 2014 F150
21
07-15-2020 12:57 PM
Lordbronn
1999 to 2016 Super Duty
03-12-2018 07:20 AM
sims1dh
2017+ Super Duty
06-20-2017 06:13 PM
Kafn8td
02-14-2014 03:25 PM
Quick Reply: How To: Install OEM Remote Start
