will not run
Old 12-18-2016, 04:23 PM
therigwelder's Avatar
therigwelder
therigwelder is offline
will not run
okay i am back revisiting a pain in my butt project.My 96 f350 powerstroke will not run.This problem has been going on over a year and several self proclaimed diesel mechanics have looked at the truck.every single sensor is brand new including the ICP also i have put a new fuel pump on it.
The truck cranks,i can hear what i believe to be the injectors clicking under the valve covers.there is no smoke.we poured diesel in the intake and it ran for a few seconds.I have off work for 3 weks and would rally like to get tis thing finally running
Old 12-18-2016, 07:01 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
Start with the simplest and easiest things such as oil level good? Check for bad fuses, specially maxi fuse #22 on the engine bay. There's a lot of stuff that will not make these beasts run, I suggest you invest on a good scan tool capable of live data testing. I'll throw a shot in the dark and say maybe your IPR O rings might be compromised or the sensor itself.
Old 12-18-2016, 07:23 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
no smoke, no fuel. uvch's might be bad or IDM might be bad. Check your fuel pressure at cranking speed. Like Adam said, could be a lot of things.
Old 12-19-2016, 07:07 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Old 12-19-2016, 08:39 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
Shawn MacAnanny is offline
My truck has been through 2 idms in the past year. No start, no smoke. If you're replacing all the sensors and taking to mechanics what's a couple hundred more for a rebuilt idm? I purchased a spare to carry and ran a direct battery ground to idm casing last time so it wouldn't strand me again.
Old 12-19-2016, 03:42 PM
therigwelder
Max fuse checked,ipr and O ring are new,idm has been replaced,cps is new,ipr wiring harness is new
Old 12-19-2016, 04:34 PM
madpogue's Avatar
madpogue
madpogue is offline
Of all the parts thrown at it, what was TESTED? And what parts were shown to be faulty? What were the results (not just "it didn't start", but what TEST results were found) of replacing each part? Shotgunning parts at a no-start is expensive to begin with, and can quickly get doubly so if it turns out you've swapped good parts out for bad.
Following the trouble tree in the link in Jarrett's post, where are you?
Old 12-20-2016, 06:11 PM
therigwelder
where i am at is no pressure at the shrader valve while cranking, and no smoke coming from the tail pipe.The FPR screen has been cleaned,o-rings were changed.I put a brand new fuel pump on.The front fuel tank is full.The wiring harness on the fuel bowl was pretty ratty so i put a new one on.The filter is brand new.There are no leaks.A friend of mine said he dumped diesel in the intake and it ran for a few seconds.I wasn't around that day to confirm it was true.Also every part ive put on the truck are brand new except for the IDM. I have a snap on 2500 scanner (red brick) will this do any justice for problem solving?
Old 12-20-2016, 07:01 PM
madpogue's Avatar
madpogue
madpogue is offline
Nothing digital will tell you about a fuel feed problem; it's purely mechanical. Have you checked the FSV? Or tried running the fuel pump supply line directly into a jerry-can of fuel, to bypass any FSV / tank line issues?
None of the wiring on the fuel bowl affects the running of the engine.
Old 12-20-2016, 07:04 PM
JAFO1's Avatar
JAFO1
JAFO1 is offline
I'm no mechanic, so I'm just throwing this out there since you have replaced almost everything. How much fuel is in the tank? If it's low, there is a chance the known faulty shower head fuel pick up is not down in the fuel. I'm not familiar with pouring fuel in the intake like you would a gasser but if it did in fact run a bit, that leads me to think it's a fuel delivery issue.
Old 12-20-2016, 08:19 PM
oldbird1965
He said his tank was full.
Old 12-20-2016, 08:43 PM
JAFO1's Avatar
JAFO1
JAFO1 is offline
I missed that. So, what if the tank selector is faulty, and stuck on the other tank.
Old 12-20-2016, 08:49 PM
oldbird1965
That's good thinking and possible.
Old 12-21-2016, 07:45 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
with an air line can you blow back to tank to see if lines are clogged
can also bypass the tank selector with hoses for a test and or use a fuel can with two hoses for inlet and return
maybe when doing fuel pump you plumbed the lines backwards?
larger line in engine bay is pump inlet unless someone swapped it out
Old 12-21-2016, 08:04 AM
bruno2's Avatar
bruno2
bruno2 is offline
You can take the lid off of the fuel filter housing and see if it is pumping fuel into it while cranking. It takes two people or a remote start switch.
Quick Reply: will not run
