61-67 econoline bumper bracket bolts
Old 12-18-2016, 03:08 PM
dennis wagner's Avatar
dennis wagner
dennis wagner is offline
Does anybody know the size of the front bumper bracket to the frame BOLT SIZE?
I know they are grade 8.
Thanks, Dennis
Old 12-18-2016, 08:09 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
7/16"-14
I'll see if I can find one to measure the length.
The Ford part number is 45550-S
Old 12-18-2016, 08:21 PM
EmilBarnabas
Strange - it is not listed in the truck parts book, except for the number.
Same bolt as the 1962-64 Fairlane rear bumper, and the 1964 T-Bird rear bumper.
Old 12-20-2016, 03:26 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by EmilBarnabas
7/16"-14
The Ford part number is 45550-S7-8
7/16" -14 x 3 1/2" long.
Old 12-20-2016, 05:04 PM
EmilBarnabas
I have a real one in front of me. Despite the fact that the Ford parts book says 7/16", I have one in front of me that is 1/2"-13. I have removed these from many Econolines from 1961 to 1967, and I think they are all the same.
The total length is 4 1/4" long. The thread starts at 2" from the head and goes to 3 7/8" from the head.
The tip is unthreaded and smaller diameter. This helps you to fish it through the frame and the brackets and helps you center the nut.
This means the picture in the parts book is probably wrong, the oaet number is wrong, and the compatibility I told you is probably wrong as well.
BTW, the nut was crimped by Ford to make it into a locknut. Be sure to use a good locknut, because you don't want these coming loose.
Old 12-21-2016, 01:30 PM
NumberDummy
Ford shows the same 45550-S7-8 part number in the 1961/63 and 1964/72 truck parts catalogs.
Also used on 1966 T-Bird rear bumper, where I got the complete part number and the specs.
Old 12-21-2016, 06:55 PM
dennis wagner
front bumper bracket to frame bolt.
So, what is the conclusion on the size of these bolts, 7/16-14 or 1/2-13?
Old 01-03-2017, 04:31 PM
EmilBarnabas
The Ford parts books are not always correct.
I have removed them from a half-dozen Econolines from 1961 to 1967, and they are all 1/2"-13. They are one of the hardest bolts to remove from the truck.
Can you try slipping a 1/2" bolt through the hole?
Old 02-19-2017, 03:37 AM
66 Evan's Avatar
66 Evan
66 Evan is offline
Some bumper bolt pictures
Hello. I was only able to save two bumper bolts. These are 1/2" bolts. I included some pictures.
Bumper bolt head.
Bumper bolt.
Another view.
Bumper bolt nut.
Old 02-20-2017, 04:40 PM
EmilBarnabas
They get rusty after 50 years. And Ford staked the nuts to make them hard to loosen.
Old 02-23-2017, 06:51 PM
dennis wagner
Thanks for the help. Lost parts at the body shop is no fun.
If they cannot be found, possibly a member has a set.
The Jeep body bolts are close but a 1/2" short. Is there an xtra 1/2" that would allow me to use the Jeep body bolts?
Thanks,
Dennis Wagner
Old 02-24-2017, 07:05 PM
Sportscape's Avatar
Sportscape
Sportscape is online now
I'm not sure if they are the same as a Falcon but you can try this.
Obsolete & Classic Auto Parts Catalogs Page 105 of the Falcon catalog
Old 02-26-2017, 01:03 PM
dennis wagner
bumper bracket bolts to frame
Thanks, I'll give them a try.
roadrash63
07-08-2014 06:50 AM
ALBUQ F-1
03-16-2011 02:01 PM
2tonsoffordfun
08-31-2010 09:07 AM
outlawnbfd
05-19-2005 08:56 AM
tapenick
01-23-2003 09:58 PM
Quick Reply: 61-67 econoline bumper bracket bolts
