1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fuel pump voltage low?
Old 12-17-2016, 01:00 PM
motoboy's Avatar
motoboy
motoboy is offline
Suspect I have a bad fuel pump. I checked for power thru the Inertia Switch.
When I first energize the ignition I receive 12v after a couple seconds it drops to 7v. Is this normal? I checked at the connector to pump module and see the same reading. I swapped fuel pump relay and same readings. Just want to makew sure I dont have some other issue before doing pump.
Thanks
Mark
Old 12-17-2016, 06:46 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Yes, that is normal.
Old 12-17-2016, 08:23 PM
motoboy's Avatar
motoboy
motoboy is offline
Thank you projectSHO89
I was figuring so but wanted a confirmation.
Looks like I get to battle a fuel pump replacement.
Wouldn't be so bad except I'm in northern Michigan and will be fighting with it outside in a portable shelter..
Thanks again
Motoboy
Prez
1997 - 2003 F150
04-21-2015 09:49 PM
jemini
01-04-2008 03:06 PM
V8 Andy
10-08-2004 07:23 PM
jwrboss302
12-21-2003 07:25 PM
bill80132
09-08-2003 09:41 AM
Quick Reply: Fuel pump voltage low?
