rear fuel tank bolts f-250 1990
The rear gas tank is leaking on my 1990 f250.
So I need to remove the bolts that hold the straps.
First, I was wondering what the size of the bolt head is? the nut is 15mm. But, I can't find a socket that fits tight on the head. I've seen others that have said it is 13mm but that socket is really loose.
And, the bolt is really rusty. I don't need to reuse the bolt. I'd just grind it off, but the tank is leaking. So, cant use power tools. What have you all used to cut one of these bolts off?
Thanks
Thanks
Thanks
Thanks
kythri
1997-2006 Expedition & Navigator
01-13-2018 12:20 PM
noaheckhouse
22
05-25-2010 11:43 AM
