Controlling Moisture during winter use?
I keep two of these in my trailer all the time.
https://www.walmart.com/ip/Ivation-I...&wl13=&veh=sem
Thanks for the suggestions. We are using it this winter in Denver. A lot of the moisture we are seeing is on the windows and the back of cabinets in the slides. Thankfully, the sun was out and above freezing today so the wife opened all the cabinets, cracked a window and turned on the vent fans to air the place out.
John
John
John
John
As was suggested cracking a vent will let some of the moisture out.
I suggested to open your cupboards some it will warm them up and the condensation won't build up as bad. If your bed is in the slide check between it and the wall you might get moisture build up there also.
Keep an eye in the corners of your cupboards, closets for black areas (mold) in the seams. A mild cleaning solution will eliminate it.
John
John
How was it in the trailer when it was -12F in Denver last week? Had a lot of friends not enjoying that. We're from there but are in Texas currently. I'm not sure how our trailer would do - even though its a closed belly....
Also have a humidity problem here as well - A lot of people have shown me that little dehumidifer that DL222 mentioned below - but I've heard varying reports on its effectiveness. One plus is it can be used with 12V.
I didn't have the utility heater in the basement set up correctly, but do now. I had the thermo king temp control outlet in the basement near the heater.... now it's outside.
Jerky's 06 F350,
As cold as it is there your Solitude looks like it should handle the cold fairly well by looking at the brochure.
I think what senix means is duct work and by the Grand design brochure you have a fully heated under belly/ storage bay (pg 5). Keeping in mind that it gets the heat from the furnace. You could plug in a 100 watt light bulb down there and it will give off heat.
-2 will test your rig for sure.
