Bypass neutral safety switch (88 F150)
1988 F150 Straight Six 4-speed Manual Transmission.
6 wires going to switch on back of clutch resivoir (grey with yellow stripe, purple with yellow stripe, green, green, darker red with green stripe, lighter red with green stripe)
Which ones do I cut & splice to bypass neutral safety switch?
Thank You,
Tim
tkassouf(No Email Addresses In Posts!)
Thank You,
Tim
You should have two red/light blue wires that you splice. Here's a diagram.
http://www.cybrrpartspro.com/Chilton.../88286W23L.jpg
Where did you do the splice? In the cab under the dashboard or under the hood, or at the transmission? I appear to be having the same trouble with my '92 F250 S/C 4x4, 460v8 E4OD tranny... on our recient holiday I had trouble several times that I traced back to the auto tranny park position. I was able to get it to go each time by rocking the truck then returning to park, but I backed it into the driveway & unloaded the camper, now I cannot get it to start again. Any help would be appreciated.
Normally the neutral safety switch doesn't fail in both Neutral and Park at the same time. In fact, Neutral barely gets used so if the contacts get bad on the Park side, it'll usually start in Neutral. The problem is probably in the wiring somewhere or in the ignition switch. Check the red w/light blue wire coming out of the ignition switch in the start position.
On my 1988 I spliced the wires in the cab right behind the clutch reservoir. I heard from someone that the setup is similar on the automatics. On my 1985 F250 automatic I spliced the two red wires on the frame running near the transmission.
If you can jump the motor at the starter solonoid with the key on and truck in park then your problem is likley either the neutral safety switch or the starter switch on the column.
Good Luck!
Tim
Good Luck!
Tim
F250_Super_4X4
12-19-2016 10:21 AM
79Supercab
02-22-2015 10:16 PM
piersol
06-05-2010 06:59 PM
