Tire Size? 275/65R20 on 2WD
Old 12-07-2016, 12:54 PM
Ben Tylka's Avatar
Ben Tylka
Ben Tylka is offline
I'm thinking about buying a set of F350 rims and tires that were taken off at 200 miles. Size is 275/65R20. Google tells me these are 34.1" in diameter and 10.83" wide. My 2WD 2003 EB ed. Ex is stock suspension at this point. Any thoughts on if this tire/wheel set up would cause me any problems. Thanks in Advance.
Old 12-07-2016, 01:59 PM
mecdac's Avatar
mecdac
mecdac is offline
You will need spacers.
Old 12-07-2016, 02:36 PM
Ben Tylka's Avatar
Ben Tylka
Is there a FTE Ex Forum approved vendor for spacers? What size? Anything else I should know?
Old 12-07-2016, 02:50 PM
mecdac's Avatar
mecdac
mecdac is offline
Old 12-07-2016, 08:44 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
The spacers Mark mentioned will be needed to properly position the late model wheels/tires under your EX. What I'm not too sure about is if 34"s will fit under a stock RWD EX, they may be a bit too tall for the amount of space you have to work with. Hopefully one of our RWD guys will see this and be able to help out.
Old 12-08-2016, 05:37 AM
DavenTn's Avatar
DavenTn
DavenTn is offline
I have the same size tires on mine.... you'll need to go here and get....
WheelAdapter.com is your number one source for wheel adapters, wheel spacers, used wheels, and wheel studs.
Old 12-08-2016, 06:22 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
Dave, your EX is a 4X4, do you think that those 34" tires would fit OK on a RWD EX with their slightly lower ride height?
Old 12-08-2016, 04:50 PM
DavenTn's Avatar
DavenTn
DavenTn is offline
Assuming that the 2WD doesn't have any addtional obstructions... then yes. I did have a rub on the plastic inner fender when it was stock height(closest to the firewall) on one side, remedied by a ty-wrap.
Myfreeford
08-05-2014 04:07 AM
flsurfprep
05-09-2011 06:07 PM
bswill32068
01-25-2009 10:39 PM
daveplot
1997 - 2003 F150
03-15-2006 06:06 PM
gr8199
02-08-2002 01:15 PM
Quick Reply: Tire Size? 275/65R20 on 2WD
