HELP PLEASE
Pretty sure it's blown. But this is my only vehicle and I can't get a new turbo till the 14th so by driving it minimum of 30 miles a day just to get back and forth to work am i hurting the engine it's self? took off air filter and The wheel in the turbo is seized
If the shafts isn't turning by hand then you're not building boost so it's going to be a dog. I would not run it. Look on Craigslist locally for a used one or wait until you have the monies for a new one.
Just as important is if you have the old steel braided pressure feed line to the turbo replace it with the updated hardline. Also replace the drain tube with the updated one.
Something made it fail, either one could of been the culprit to seize a turbo.
What year is the truck you have a 2017 listed and I know that they did not
have any 6.0Ls in that year.
Hit this guy up over on Ebay His name is Eric and he has good prices and
a few of the guys have gotten things from him and are happy.
vampkittykat on eBay
Send him a message letting him know what you want.
In the past I have picked up a turbo,New style oil feed and a mount.
What he does is decommission E-series Emergency Service vans and some trucks.
So he has a lot of part that are not listed in the auctions. But like I said if you don't
see what your after send him a message.
Sean
6.0L Tech Folder
Sean
6.0L Tech Folder
3C3Z-6K682-CCRM /Turbocharger1F350; 6.0L DIESEL; TO 9/22/03
4C3Z-6K682-CDRM /Turbocharger1F350; 6.0L DIESEL; FROM 9/22/03
IIRC the mounting bolts are configured differently so you would need the pedestal too. I would avoid it and get the correct one. Depends on your build date and if the engine is original to begin with.
This is also another option, and a number of smaller diesel shops offer this new turbo around the same price.
https://www.amazon.com/Turbo-Replace.../dp/B00J5NQKVQ
If it's seized would I be able to get it working again without rebuilding it? took off air filter sprayed son carb cleaner in there got it to spin quarter turn around.vwas told to take off oil feed line and start truck real quick just to make sure it's getting oil. any body else have any recommendations?
