View Poll Results: Using rear helper springs when towing RV?
YES
13
40.63%
NO
15
46.88%
Planning to
12.50%
Voters: 32. You may not vote on this poll
Poll: RV'ers using rear air bag helpers or not?
Just wondering how many people towing RVs are or are not using rear air bag helper springs. Thinking of buying some this spring- towing 8500# travel trailer with tongue weight of about 1500#, rides pretty rough on bad interstates. May move up to 5th wheel at some point. Have factory 5th wheel hitch package, 6.7 Powerstroke Crew Cab.
My year truck has an issue with rear sag with a light load. There is a TSB covering the issue and a fix to be paid for by the customer. If I were to go Ford's route to fix the sag it would cost close to $2000.00 in parts alone. So my solution was to install air bags. I chose Air Lift air bags for around $300.00 IIRC and they work great. Keep in mind, they will not increase your vehicle's cargo capacity, they will only level the load. I really haven't noticed much of a difference in ride quality - I've had them for over a year and forget what it was like without them. When empty, I keep about 10 psi in the bags, when I hook up I add air until the truck is level then set the weight distribution bars if applicable (boats don't have them, one TT does).
[IMG][/IMG]
[IMG][/IMG]
There are so many Pro's & Con's on this subject. Are Air Bags the devil ? Absolutely not.
With so many different circumstances I don't believe there is any one perfect solution.
In my case, Air Bags are my preference when I'm carrying our Slide-in Camper. Campers are heavier on one side. With Air Bags I can level my Side to Side weight differences.
As for the weight support of the Camper, between having enough
Truck in the first place, adding Air Bags, Big Sway Bars and quality Shocks are all I've
needed for the continuous weight changes of carrying our Camper in the past.
Air bags and helper springs are two different things. Which are you asking about? I use air bags but only need about 15 psi to firm up the ride. I have no sag either way, the bags just stiffen the ride a little when towing. I run 5 psi when not towing. If you go air bags, play with the pressure when towing. I found that too much pressure can be detrimental.
What does SRW vs DRW have to do with the effectiveness or lack of effectiveness of air bags? Just curious.
If a truck sags when loaded or sits one side low when loaded, airbags can be a great improvement. Always set them up for separate fill.
