looking for alignment specs for volare front clip on a 51
So I'm finally getting my 51 ford truck diving again and its time to take it to the alignment shop. I'm not sure if I should be asking them to use some special other alignment range or just go with the factory alignment specs for the Volare.
Make certain you have the ride height where you want it before aligning - even small changes in ride height afterward can cause tire wear issues. Chrysler t-bar suspensions (and Ford Twin-I-Beam) need good shocks to keep tire wear in check.
My 2¢, for what it's worth... Camber isn't as effective as caster to compensate for road crown. Less than ½° camber can sometimes make a vehicle with radials drive sloppy. Typically 1/2° more positive caster on the right will compensate for 1½" of road crown.
thank you both for the input. I'm hoping I can get to three degrees of caster. with the volare clip welded in the way they are it seems like the uncertain part. I was going to take it in tomorrow but I'm getting a weird vibe in the rear end I need to track down before I drive it in to town. probably tires went bad sitting so long. and maybe because I might have used them as supports to place the rear end on when I was welding on it. we will see.
I think those's had slotted holes that the upper control arm bolts slid in. You can always take a die grinder and elongate them. I had to do that on my MII set up. I followed the instructions and was to have something like 33'' between the center of the shock mount holes. Thats what I had right on and when I aligned it I had way to much positive camber. Had to make the slots like 1/2'' longer.
robotunderpants
20
11-05-2016 12:30 AM
rchassie
09-11-2012 12:20 PM
sandman3510
07-27-2004 04:57 PM
