New truck and engine build
Well I have been keeping an eye out for a loaded 05-07 CCLB (not white or black ) and finally found one in my price range.
To get it in my price range I went looking for one with a popped motor.
I found an unmodified Blue 06 that seems to fit what I am looking for. Apparently the PO overheated it enough to make the oil smell burnt and lost compression in at least one cylinder.
I am not planning on building a high horsepower motor as it will spend most of it's time unloaded. I do not tow very often at all but do need a truck for picking up loads of steel and various large objects so I don't see a need for an all out motor. I currently have a 97 powerstroke (SCLB).
The truck has ~200k on it.
I have a line on an 06 theft recovery 6.0 (missing turbo and injectors) that has ~120k that I can get for pretty cheap.
My plan is to rebuild the extra motor and then swap them.
Given the mileage on the theft recovery motor I was planning on leaving the bottom end un-touched (pending inspection) except for re-sealing the bed-plate, front and rear main seals, BP water pump, and paint (black is boring and you can't see oil leaks). Not even sure bearings are worth it if they look good.
For the top end I am planning studs and egr delete. I will have the heads checked but again with the mileage I am not expecting much but I will have the valve seals and maybe the injector cups replaced.
I have built several motors in the past (though not a diesel) and very much enjoy it so I am looking forward to the build.
I had a few questions:
1. egr delete - is it still general advise to leave the valve in rather than use the block-off that most kits seem to come with?
2. Given the overheat condition of the old motor should I expect the turbo or injectors to be damaged?
3. How durable are the 5R110 transmissions on a stock engine? I have almost 300k on my 97 4R100 and it is just starting to show some shifting issues (no slipping but hard 2-3 shift sometimes).
I have started a spreadsheet of the parts list that so far looks like this:
Ford head gaskets (2)
Dummy Plugs (2)
Stand Pipes (2)
Injector Oring kits (8)
Injector copper washers (8)
Thermostat
Teflon Sealing rings for Power Steering and Hydroboost (6)
arp Head studs
Oil cooler
EGR Blockoff
Tunes to disable EGR
Water pump
Fuel pressure blue spring kit
exhaust manifold gasket (2)
Intake manifold gaskets (2)
Bedplate Seals
Permatex high tack spray
RTV Sealant TA-31
Oil pan gasket set
Rear main seal
front main seal
Valve cover gaskets
rocker box gaskets
updated Pushrods (maybe)
Am I missing anything?
I have thought of getting the Ford overhaul kit due to it's completeness but that includes pistons and bearings that I am not planning on using so will likely be more expensive.
For a tuner/monitor, I hear PHP is coming out with a special version of the Edge insight Pro CTS2. With that I figure I can get a monitor and tuner all in one.
I am open to comments and/or suggestions.
Richard
Dummy Plugs (2)
Stand Pipes (2)
Thermostat
arp Head studs
Oil cooler
EGR Blockoff
Water pump
Bedplate Seals
RTV Sealant TA-31
Oil pan gasket set
Rear main seal
front main seal
Valve cover gaskets
rocker box gaskets
Richard
Cool! Looking forward seeing the build!
Personally, I would also have planned to replace all the injectors with motorcraft rebuilt ones as well as a rebuild kit for the turbo. I am also one of those who prefer to keep the EGR cooler, albeit a bulletproof version.
good luck!!!!
good luck!!!!
WRT the injectors, I might if budget allows but the injectors in my 97 are original and run fine. I would expect with a similar design in the 6.0 that they have plenty of life left if the overheat didn't damage them.
In my initial plan I want plenty of budget buffer in case I run into something unexpected.
I never thought of rebuilding the turbo, I figured on replacing it if there were issues. A new stock turbo is pretty cheap as far as turbos go. Have a link to the process?
I also have another question to add...
4. if i switch to the ELC coolant, is coolant filtration necessary?
richard
You mention it got hot, hot enough that the oil smells burnt. I'd first pull the oil filter and inspect the plastic standpipe. It is an indicator to how hot it got. If that standpipe is melted gone, I'd probably look for another block because all that plastic will be stuck in the oil galley and who knows where else.
Definitely new lifters and pushrods.
Some of the items you don't have to buy separate. Ford offers them as a kit. For example the oil rail standpipes and dummy plugs. For a little over $100 you get all 4 updated ones in one package instead of each piece separately. #6E7Z-9A332-B
For turbo I'd split it and inspect/clean or replace the unison ring and reinstall it. Ford also offers a install kit for this.
I'd scratch the injector cups,, you'd be opening a can of worms that doesn't need touched. This isn't a 7.3.
Rear cover gasket
Hpop seal kit (or stc kit)
Inj crush washers come in Inj seal kits
When I raise cabs,, 2 Teflon seals are needed
Turbo install kit
Exhaust mani bolts n spacers
Y pipe and up pipe bolts and gasket
Y pipe
Donut gasket comes with front cover seal kit (that would scratch the front crank seal, and front cover gasket)
Belt
Pick up tube oring
Cam n crank sensors (or at least orings for them)
Block heater oring (I like taking them out and cleaning them with brass brush bench grinder)
Glow plug wires,, and glow plugs
Flex plate bolts
Torque Convertor nuts
Harmonic balancer bolts
Lpo oring
I replace the lpo regulator
I'm sure I'm forgetting stuff.
Rear cover gasket
Turbo install kit
Y pipe
Belt
Pick up tube oring
Flex plate bolts
Lpo oring
Rear cover gasket
Turbo install kit
Y pipe
Belt
Pick up tube oring
Flex plate bolts
Lpo oring
Rear cover gasket
Turbo install kit
Y pipe
Belt
Pick up tube oring
Flex plate bolts
Lpo oring
I also have a CNC machine in the garage so making the odd shaped, back of the head piece is really simple.
Thanks for the updated parts... I talked to one of the well known local machine shops and they said that they almost always have to deck the heads (they even had to on a 60k engine) but it's not a lot. Everything will likely get here in January so I am in planning stages now. Everything might change once the engine comes apart.
Richard
I won't be lifting the cab, I'll be making one of the engine lifters that attach to the front of the engine and the back of the head to pull it out the front ( Diesal Engine Lifting bracket from Ford Book - Page 2 - Ford Powerstroke Diesel Forum ).
Richard
Richard
That was a head straight off the ford parts desk.
I shot this a couple years ago but it's worth bringing up every now n then.
https://youtu.be/EjayM4Kf8BM
Richard
Farmboypowerstroke
11-27-2013 12:22 PM
upnorthf250
03-07-2012 10:29 AM
