Window thread with twist
So with searches not really turning up anything...Thought I would post.
2005 F250 6.0l Lariat CC.
The drivers window will not work if the temp dips below 60 or so. After the ambient temperature comes up, everything works as should. When truck is first started, the window will sorta "click" when the down button is pressed but then will quit. Sometimes cycling the switch rapidly will cause window to work but often times you just have to wait until outside temp comes up. All other windows work perfectly.
Anyone out there have/had this problem. I am not sure if it could be related to the mirror heaters drawing too much current (idk...just guessing here).
Really strange. Anyone have ideas. Hate to buy a new switch when it works when it works flawlessly most of the year. Just kinda hard to go through drive through on the way to work in the mornings!
kefrko
10-23-2017 10:35 PM
