1982 5.0 vs 2000 5.0 short block
What are the main differences in the short block of the past (60s-80s) vs the named explorer gt-40p blocks ? ( if you took the heads off of them and just had the block and internals what are some of the differences?
I know of
cam gears
fuel eccentrics
and the two piece rear mains.
I know of
cam gears
fuel eccentrics
on
All 5.0 blocks cast after 1987 were roller ready with raised bosses in the lifter valley to accept the factory spider retainer assembly, and the lifter bores are slightly taller and machined flat on the top to accept the taller roller lifters and dogbone which prevents them from turning.
Some early blocks are a little heavier but it's not enough to make a significant difference in strength, none of the factory blocks are strong enough for high rpm(7000+) operation or blown/nitros builds in excess of about 450hp.
Fomoko1
31
03-16-2010 09:23 PM
mstrelectrician
09-20-2007 12:18 PM
unleashed
07-17-2007 11:06 PM
bron1967
10-22-2004 12:40 AM
art015
04-24-2004 11:03 AM
