Rear exhaust hanger
Rear exhaust hanger
The rear hanger insulator broke long time ago on my 94 F150. I had it wired up until the the pipe attaching to the muffler broke off. I finally got everything welded back together and am now ready to hang the exhaust system back up. The problem I'm having is I can't find the OEM hanger for the rear. The generic ones I find look like they have no insulator. I don't want to micky-mouse the system and end up having the pipe break off at the muffler again.
Anyone know where I can get the OEM hanger?
let me know if you find something.
I had a shop replace my exhaust pipe with a shorter one, they did not do a good job, the shop closed also I should mention.
now I have a exhaust they swings from side to side and rattles.
I havent taken it back to another exhaust shop again.
I tried to fix it myself, but havent had any luck making a bracket, and attaching it to the exhaust.
My exhaust broke because one of the rods that the pipe hangs broke off because of rust. The isolator in the rear also broke. I was hoping to replace the isolator but the hanger is riveted to the frame and the hanger itself where the isolator attaches is made of brackets that can be disassembled without grinding it all apart.
I don't want to make a cheap repair that will cause the pipe to break again.
None of the muffler shops near me will lift a finger for less than $50 plus they're not open after 5 nor are the open on weekends.
Does anyone have a part number?
F3TZ-5260-B .. Bracket-Outlet Pipe to Frame / Available from Ford, but you'll probably have to order it.
No one in 1D - OR - WA has any in stock. Closest dealer that has stock (3) is DeLong Ford in Winnemucca NV = 715-623-5001 x 1118.
88 FORD: 1983/91 F150 (E3TZ-5260-A) is not the same. It's obsolete, no one has any.
Last edited by NumberDummy; 11-13-2016 at 06:28 PM. Reason: Ford dealer parts locator back online.
wildstang
06-20-2017 09:26 AM
AnimalMother
17
05-24-2016 10:48 PM
