What fluids to use?
What fluids to use?
Ok, plan on servicing my 04 F250 5.4 4x4. Want to change the fluids in the front and rear diff and the transfer case.
1- how much fluid does each require?
2- What type, grade and brand should I use "Mobil 1 syn. for all"?
3- any other additives needed, it has a limited slip I believe
I use Mobil1 in the engine..
1- Rear differential takes just over 3L I believe.
Front takes 2L.
2- Motorcraft 75w-140 synthetic for the rear, and 75w-90 4x4 fluid in the front.
3- Crawl under there and look at the tag on the rear diff. It'll tell you if you have the limited slip. If you do have it, throw in 8oz of friction additive.
Transfer case fluid is simple. Should hold 2L. At the autozone by my house they didn't have motorcraft transfer fluid. They did have Valvoline transfer in stock, so I used that instead.
Front takes 2L.
Website below was created by a member of FTE and has some excellent instructions plus pictures.
2004 F250 Super Duty 4x4
Ibarria
1997-2006 Expedition & Navigator
01-04-2007 03:02 PM
