Brake wires
Brake wires
I posted in the wrong forum first time.
Fellow RVer is coming by to compare my brake wiring at the hub to his. He blew a tire. 2010 Mountaineer 5th wheel 324 RLQ (Yes, we have the same one)
I just looked at mine. I have 2 white wires dropping out of the floor to drive side axel. (side the tire blew) I can't see a difference between the 2 wires. No markings.
They drop to the cross over wires to the passenger side, which one is a brown color, the other white.
So, How do we figure out which white wire goes to the brown wire and also the other white wire to actual brake?
wire 1 = white to brown and white
white 2 = to white
Thanks
white 2 = to white
Thanks
Thanks Steve and Denny.
Got the wire that crosses over clean enough to see that one has a black stripe. so that is a good thing. He didn't have anyway to check for power. I did in my truck, but, sadly, we have one vehicle and wife was at work! Figures.
I haven't spoken with the guy since, so not sure what he wants to do from here.
Received 6,718 Likes
on
sorry to hijack.
is it Common for brake wire connections to ONLY use wire Nuts ? and not solder them..
right after dealer replace all my brakes under used trailer warranty... I seen the new wire nuts.. SO I removed them and soldered all and also the break-away circuits.
steve
