Preditor Generator
Preditor Generator
My 8KW generator with a chonda engine has two problems now. Ran fine when I put it up in climate controlled storage 2 months ago with sta-bil in the tank.
Got it out and started it. Fired right up but now has a random hard bump without changing rpms and when under a load, sounds like its clattering.
Could it be some fuel mixed with the oil? When I put it up, The fuel filter I installed was full of fuel. Now it was empty like it leaked into the carb.
Plan on doing an oil change tomorrow but just wondering what else it could be. It only has 3.3 hours on it.
Also, My fuel keeps changing colors from clear with a blue tint which is typical to orange. Tank has no rust. It will change just sitting in the filter after a week.
Received 3,108 Likes
on
that is part of the problem with the cheap china gensets and parts.
the fuel tanks are made of the cheapest plastic know to man and the plastic is chemical reaction with the fuel causing it to turn bad.
the filter leaking dry could be bad seals letting air in to evaporate the fuel, or bad needle and seat in the carb.
I knew it was no good for vehicles but now its not even good for a small engine....Only thing I could get at the time too..... Pure gasoline would be excellent....If I could get it. Only thing around here is 10-20% mix.
Its not that its a Chinese genset as to why. Alot of your top name are built in the same factory on the same line as these just different names and stickers.
on
