Tornado fuel saver
Old Dec 12, 2001 | 05:52 PM
bigred78's Avatar
bigred78
Tornado fuel saver
Has anyone else seen this on tv. I want to know if it really works as good as they say. They have a website atwww.tornadofuelsaver.com.
It makes sense that by turbulating the air it would mix the fuel and air mixture alot better resulting in better combustion.
Bob
Old Dec 12, 2001 | 06:37 PM
Bill_Beyer's Avatar
Bill_Beyer
Tornado fuel saver
Numerous tests have been done by consumers groups, enthusiast mags, etc. and they all came to the same conclusion:
It doesn't work. Period.
Old Dec 12, 2001 | 08:24 PM
Greywolf's Avatar
Greywolf
Tornado fuel saver
In all of the supposed "fuel Saver" literature I have read, and even SENT for, at times - one thing only comes out of it all:
Fuel needs to mix well with the air coming into the engine intake manifold. Sometimes problems are caused by fuel condensing on the sides of an intake and forming puddles that drip un-mixed raw fuel into a cylinder (occasionally causing what we call a "Wet Plug") and in that form it will be blown out the exhaust, never to provide the power that might have been obtained from it.
The better fuel swirls AFTER IT IS INTRODUCED TO THE ENGINE, the better chance it has to mix, and that is a primary consideration in intake manifold design and testing. It is also at the forefront of every engineers mind when they think about valve flow, and upper chamber design. This thinking brought about the "Quench Head" upper chamber layout...
In the designs I have looked over for theoretically outrageously high milage carbuerettors, the common theme was to heat the fuel until it went from a liquid to a gas state, and them mix it with incoming air so that instead of being atomized droplets suspended in the airstream, the fuel would truly mix as a gas.
For whatever reason, we never saw this idea take hold and become prevalent. Some argued that it was because the petroleum companies would lose money - and bought the patents to stifle the idea.
We are currently standing on the edge of the alternative fuel era. What happens next is a coin flip - but I can't get over the idea, the feeling - that somebody has been lying somewhere.
And now we are about to make another major change....
Scaled over enough years so that fuel companies and their stock holders still make a buck
~Wolf
Old Dec 13, 2001 | 07:45 PM
caseman's Avatar
caseman
Tornado fuel saver
OK, so they want to mix the gas and air better by swirling it. Might work up to a point. But remember you can also separate the oil mist in an air compressor's output by swirling it, and some industrial type air cleaners work by swirling the air to sling out the heavier stuff. At what velocity do you start slinging the heavier gas out of the mixture? I am not sure they know, and I don't think the velocity is that controlled all the way through the intake. Too many changes in direction, not to mention engine rpm affecting velocity. Hmmmmm.
Old Dec 15, 2001 | 09:11 PM
pickupman's Avatar
pickupman
Tornado fuel saver
Cruiseomatic
Nov 8, 2016 07:40 PM
trike1946
Jun 23, 2013 01:24 PM
