How to tell wich gear set in rear end
Old 11-04-2016, 08:53 AM
1950F2's Avatar
1950F2
1950F2 is offline
I have a stock 1950 F2 with flathead V8 3 speed on floor. Does not like to run much over 55mph..rpms are maxed out. Have tires within 1 inch of stock hieght. The shop book says it can have either 4.11 or 4.857 gears in it.
How can I tell without tearing the rear end apart? I want to keep it stock and not change rear ends. Chuck's trucks has a 4.11 set, just need to know what I have now.
Old 11-04-2016, 12:22 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
The stock ratio was the 4.86/1. I've heard of a handful of 4.11s having been found but it's literally a handful. Four or five. It's common for the ratio to be stamped into the differential housing. If you don't find it you can determine it by blocking a rear wheel, jacking up the other side, chalk mark the elevated wheel and drive shaft, then rotate the wheel TWO turns counting the drive shaft's revolutions. Almost five is the 4.86/1, slightly more than four and you are a winner. IMHO you're already a winner having the 3HD tranny since it is synchro on 2nd and 3rd.
I have Chuck's 4.11s in both my front and rear axles. Stu
Old 11-04-2016, 03:37 PM
1950F2's Avatar
1950F2
1950F2 is offline
Thanks Stu. I will check the wheel rotation out. I will also look for stamped numbers on axel.
How hard was it to change gears?
Old 11-04-2016, 04:25 PM
truckdog62563
Ummm, easy for me. Chuck did it. He's described it in other threads, though, for other guys that have done theirs. You might do a Google search. Stu
Old 11-05-2016, 10:21 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Here is a thread with pictures and description of a truck owner who purchased and installed one of Chuck's 4.11 kits: https://www.ford-trucks.com/forums/1...onversion.html
Here is a second thread with a 4.11 kit install: https://www.ford-trucks.com/forums/1...mission-4.html
Last edited by 38 coupe; 11-06-2016 at 11:48 AM. Reason: add link to second thread
Jolly Roger Joe
10-14-2012 05:34 PM
86'f250
03-21-2006 12:33 AM
67fastbackfreak
07-31-2004 02:20 PM
joners
06-27-2003 11:53 AM
Mil1ion
04-08-2002 09:33 AM
Quick Reply: How to tell wich gear set in rear end
