I changed out the bad bulb for a new 194 LED bulb and it still doesn't work. So it leads me to believe its a bad fuse. I'm looking at my Manual and no where do I see the fuse location for the Shifter light. The light that lights of the shifter so you can see if your in Drive or Reverse or etc...
I have a 2004 Ford F150 Supercrew. Thank you so much for your help, this ones blowing my mind... Just simply can't find it
Okay, I fixed it. No idea which fuse it is on but I literally pulled every single fuse out and checked every single one. All fuses were good, but one of the fuses had a loose connection. The light works now. If anyone still wants to take the time to tell me though which fuse, I'd still love to know. Thank you!
Why don't you tell us which fuse was loose.... then we'll tell you if it might be the right one.
Frankly, your initial post was so lacking in pertinent details as to make it impossible to research your question. It hasn't gotten any better.
It was lacking information? You know the shifter that shifts you from Drive to Reverse to Neutral.. That thing has a light that will light up the letters so you know which mode your shifter is in. Wouldn't want to accidentally back up into your house would you.. Well that light is getting power from a circuit that leads to a fuse in your fuse box... This was all said in my first post, and I am wondering which fuse in the fuse box it is. How was my post lacking information? There is literally no other information I could give. I named off my truck model and year and everything. What other information did you need?
PS: I didn't catch what fuse was loose, I didn't notice any that were loose but apparently there was because the light worked after I pulled all the fuses out and put them back in. So I'm assuming there was probably a loose fuse.
