Is your anti-lock light or brake light on or flashing? This happened on my Dad's 94 F-250. On my way to town one night, the anti-lock light came on. After I made my first stop, got back in the truck. It would start up, but the shifter would not move. I noticed the antilock light was on. I looked in the manual, and it said if the light was on(or flashing, I can't remember which), to check the fuse. Sure enough the fuse was bad. I replaced the fuse, the light went off, and the truck would now shift. I guess it is just one of the safety features.
It has a short somewhere in the circuit. I am not sure what all is controlled by that circuit. You may have to trace the wires to find it. Look in the trouble shooting section of you Haynes manual. It may give you some advice.
Spoke to a cousin of mine that works at a Ford dealer. He told me the problem is probably with the brake light switch. I took the switch off put in a good fuse and started the truck. Then I checked the fuse and it wasnt blown....I am waiting to hear from him if this will confirm or refute this being the problem.
