390 stroker or 460
390 stroker or 460
I think the 460 will be chaper than a SCAT stroked 390 using new parts. But, you can storoke a 390 using Ford parts, like a 428 crank.
Use the search feature for recent discussions on FE strokers and FE vs 460 comparisons.
Note:that if your vehicle is already FE equppied (360/390/428), the changing to a 460 will require several other parts like motor mounts, a compatible transmission or bellhousing and possible driveline legnth changes as well.
The FE 390/428 and strokers are capable of plenty power, and we just like them here in the FE Forum :-)
390 stroker or 460
It si really pretty simple, more cubes will get more power. But, if you have to convert other pieces, the conversion may not be worth it. You can get an FE, with over 500 cubic inch displacement. It only takes $$$
BTW ,I'm waiting on my stroked 428, at 446 cubic inches from Flatlander Racing. As you can see, I like the FEs :-) It should make 475+ lb-ft of torque at 2000 RPM :-) Just what I need for an old, heavy 3/4 ton truck.
76CamperSpecial
26
04-01-2019 06:46 AM
F350moneypit
08-23-2009 06:29 PM
cowboy.2010
29
02-08-2009 05:13 AM
yrnutt
10-20-2006 05:56 AM
chilly460
58
09-13-2001 06:57 PM
