Towing
I think unless you have the 8' bed, a 5th wheel is going to be an unnecessary headache. even with a 6.5' and a shortbed-friendly cap on the trailer or a slider hitch, I'd still opt for a bumper-pull. The biggest benefit of a 5th wheel is that it positions the pin (hitch) weight over the axle. Too much weight on the bumper can create real problems but with super light loads, that's a non-issue. IMO unless you're looking to tow over 5000 lbs, bumper pull is the way to go.
The biggest problem is king pin weight. A lot of F250s pulling 5vers are technically overloaded on paper, but the margin of safety is still there because the main components (frame, brakes, driveline, tires) are basically the same between F250s SRW F350s. RV weight tags are very, very skimpy compared to what the real weight can be, unless someone can show a scale ticket never trust what they say they're running for pin weight. 1/2 ton towable 5vers exist, but the pickings are much more slim simply because of design and the higher pin weight they carry versus tongue weight on a bumper pull. Some literature says 20% pin weights, but 25% is closer to accurate for a lot of designs and how people load the trailers. That 5% difference is 450# on a 9k trailer, pretty easy to sail past the F150 ratings where the wheels and P-metric tires don't have the same leeway as E-Rated tires on an SD do.
Step #1 is something most people don't bother with, and that's weight the truck itself to see what you even have to play with. Payload guide for 2016 attached:
There are fifth wheels which are, in theory, 1/2 ton towable. You would have to know the pin weight of the trailer and the load capacity of your truck, both to support the pin weight and to pull the weight. You also need to take into consideration the weight of your passengers, luggage, fuel, etc. and everything else you will carry in the truck.
I've got a 5.5' bed and I had 1,500lbs of remaining capacity over the rear axle when I first bought the truck (weighed on a truck scale, just me in the cab, no gear loaded). Lot's of people tow with a 6.5' bed, but you'll lose another 100lbs (if I remember correctly) going with the longer bed. Add in the weight of a hitch and gear, and you're quickly approaching 1,000lbs remaining capacity. I don't have a trailer now, but have in the past, and agree with the 20% pin estimate. I was a weight-nut and scaled my system (31', 9,200lb pumper-pull) at least once a year. It's very,very easy to add 1,000lbs of gear without looking. At least it was for my family of four.
Something else to consider is many people complain about how quickly these current gen trucks squat under the weight, so you may also need to add some kind of suspension assist gear (that's a separate conversation...mild to wild). I've got 600lbs of gear in my truck (canopy, gear, Decked system). I've down to a 1" rake now; basically leveled, and she drives like an old Cadillac when loaded for the weekend.
E350turbo
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-27-2004 05:28 PM
TBible
Fifth Wheel & Gooseneck RV Towing
07-02-2003 04:40 PM
DeenHylton
10-01-2002 05:31 PM
