HELP! 1985 F150 VIN DECODE
I do apologize if this has already been asked, I did a decent amount of research prior and couldn't find my specific year or range. So if anybody can decode this for me properly and/ or redirect me to a TRUE WORKING decided I would greatly appreciate that.
1985 Ford F-150
4.9 I6
4 speed manual
Vin # 1FTDF15Y7FNA85998
thanks and God Bless
1985 Ford F-150
4.9 I6
4 speed manual
True working what?
Anyway, just use the VIN decoder here on FTE - VIN Decoder - Ford Truck Enthusiasts Forums
Bar none information?
I tried it and it worked. There's only so much info in the VIN. Year, model, engine type, cab/bed type IIRC, country of manufacture. Has nothing to do with record-keeping.
Try this link:
http://www.shopkeysupport.com/sk5com/vin/vin.pdf
It is a manual decode, meaning it's NOT a "enter the VIN and it's automatic", but a good resource.....Once there, Ford starts on page 79.
There's only so much information the VIN gives you...
1: USA
FT: Ford Truck (Completed Vehicle)
D: (GVWR) 5,001-6,000 lbs
F: (Model) F-series pick-up, regular cab
15: (Submodel) 150 series Styleside & Econoline
Y: Engine Type (??? you said I6 but I couldn't find this in the tables)
7: Check Digit (no meaning)
F: Model Year (1985)
N: Factory (Norfolk, Virginia)
A85998: Production number
References:
https://en.wikibooks.org/wiki/Vehicl...Ford/VIN_Codes
Ford Motor Company VIN Equipment Codes
https://en.wikibooks.org/wiki/Vehicl...es)/Model_year
1: USA
References:
1985 Ford F-150
4.9 I6
4 speed manual
1985 Ford F-150
4.9 I6
4 speed manual
I appreciate all of your help and info y'all. And I appreciate your time and patience. This has definitely been a push in the right direction. I got this F150 2 weeks ago for $780 pretty much, has a rebuilt T170FT and pretty much all new parts in and out. 6,000 miles on rebuild, 230,000 on body, owner before me over carbureted it by 200 CFM with a 625 Street Demon 4BBL and put a not so good offenhauser DP Intake on it. Been somewhat of a nightmare just to get her tuned to 17 inches of volume.
Id love to trade it and go back to factory.
You can easily decode everything yourself on Gary's site.
VIN here: VIN Decoding - ???Gary's Garagemahal
Certification Label here: Certification Label - ???Gary's Garagemahal
The items surrounded by blue boxes are clickable and lead one to more specific information.
Welcome to the forum.
Dave ----
VIN: 1FTDF15Y7FNA85998
D = Class D - Hydraulic Brakes - 5,001-6,000 lbs. Gross Vehicle Weight Rating.
F15 = F150 2WD Pickup.
Y = 4.9L (300) I-6.
7 = Check digit, FoMoCo use only.
F = 1985.
N = Norfolk VA Assembly Plant.
A85998 = 1985 Numerical Sequence of Assembly, the trucks specific serial number.
