Best fastener assortment kits
Hey all! I'm looking for a good assortment of nuts, bolts, washers, and maybe even clips and pins, screws etc. I used to live in NY and now live in Washington, so I wasn't able to bring all the little extra goodies with me. It sucks having to run to the store every time I need a nut or bolt.
Has anyone purchased an assorted kit, preferably with storage, that they really liked for a good price? I'd like to spend under $200 if possible. Thanks!
Received 3,150 Likes
on
on
fastenal is real good. i only use grade 8 nuts and bolts.
i also buy crimp connectors in the 100 or 250 piece bulk packs, and only buy scotch or 3M brand
if they do not have the good stuff i just place an order and pick it up when it comes in.
my days of doing things twice because of cheap parts is long gone.
I get my butt connectors at Fastenal, but I get the self soldering heat shrink ones. No damage to the heat shrink from crimping, and a soldered joint every time. I was introduced to those working on potato hauling trucks, that was the only thing that lasted any length of time for the taillights.
Jared,
you're talking about something like this, right?
I'm a little surprised because solder isn't known for mechanical strength. A proper crimp is stronger than the wire. A pull test will break the wire, but it won't pull out of the connector.
Maybe the vibration was affecting the crimps -- of course, to really get a good crimp you need a ratcheting tool designed for the specific connector.
Whatever, if it works, you can't fix it.
hj
hj
pineconeford
11-22-2012 05:57 PM
Schuyles
31
08-27-2012 08:57 PM
thorswhisper
05-08-2011 06:02 PM
3Mike6
N. California Chapter
10-24-2006 11:31 PM
