Tailgate is right up against the trailer when connecting
Towed my 5th wheel yesterday for the first time. WOW what a difference than my '03 Ram. Nice smooth ride, plenty of power. Didn't even notice it was back there. Ran into a little issue when hooking up, the tailgate was right up against the trailer. The truck was straight to the trailer. Also notice that there is not a lot of room to walk between the bumper and the trailer. Has anyone else experienced this? Luckily I have a sliding hitch but this is going to be a pain to have to slide the hitch back every time I hitch and unhitch.
John
John
That doesn't sound right. On my rig with the tailgate down there may be 12" of clearance from the outer most edge of the tailgate to the front of the 5ver. Closed, I probably have 18-24", enough to walk between anyway. I have a demco autoslide, that when straight is fully forward. Are you sure your hitch is installed correctly? I don't mean to sound condescending, its just that I've never heard of such a problem.
Can you post any photo's that show your hitch, and your pin box?
With my 03 F350 CCLB I have only 4 inches between the front of my 02 Carriage Cameo with tailgate down. It is not really a problem as when it is up I can walk between them and there is plenty of room to turn even past 90 degrees. I do however normally back under just far enough to close the tailgate before hooking, gives me more room to hook up wiring. I haven't had any problems although a friend who does the same thing forgot the R was reverse and put his truck in drive instead with the resulting remodeled tailgate.
On my 2013, short box. I got the Reese #50073 no drill mounts for the frame.
Rails: From the end of the box (tailgate) to the back of rear rail, I'm 32 1/2 inches. Give me about 2-3 inches when hooked up to the fifth wheel.
I don't think a long box would help. Isn't the difference in size from the cab to the axle?
Yea, something isnt right. In my shortbed, when I'm hitched up, it looks like your truck in the maneuver position. I'd actually be afraid to turn corners in your rig as close as that is, even with the tailgate up. Can you take a couple more photos down into your pickup box of the hitch? And a photo of the entire pin box? It seems like your hitch is mounted too far forward, or your pinbox is too short. In your last photo, it almost looks like the kingpin is way forward of the rear axle too. Did you buy this trailer from a dealer? If so, I am very surprised they didnt say anything?
