transfer case fill plug stripped
I assume you mean the HEAD is stripped so you can not grab it. Normal procedure is to use vice grips if the head is exposed and rounded. If this is countersunk and a hex drive (etc), you can drill a 3/8 hole thru the plug and pound and extractor into it and screw it out, or you can get someone to weld a bolt to the plug, then grab the bolt head and screw it out.
If I had to do that on a fluid plug, I'd rather smack myself in the nuts with a claw hammer.
If it's an exposed hex head that rounded off, grab your dremel and grind a couple flats on it for a wrench to fit. Hit the threads with PB Blaster for days in advance and it just might work.
you can also use a chisel and hammer on the outer edge, trick is to find a chissel that's about half dull, otherwise to sharp and it'll just take chunks out of the plug.
prolly ought to get a new plug before hand, just in case
suthrnslew
22
06-04-2009 05:10 PM
Me Myself
09-01-2007 03:46 PM
MetallicaFan39
09-14-2004 09:53 PM
