EGR Delete's and tuners question.
Old 10-08-2016, 09:23 AM
duste's Avatar
duste
duste is offline
I am in the middle of replacing the head gaskets and now getting to the EGR system. I am aware that if you delete the system completely you will require a tuner to eliminate a check engine light for the EGR. Here's my question, if I weld the factory cooler shut and put it back in place , it eliminates the function of the EGR , but does this method also require a tuner? I was under the impression if you go the welded route you did not require a tuner but somebody here on another post claims you still require a tuner to get rid of a check engine light. The truck is a 2007 6.0. . Thanks.
Old 10-08-2016, 09:30 AM
Per4mance's Avatar
Per4mance
Per4mance is offline
That is correct,you need a tuner to shut off the check engine light. If your that far into it,get a IPR delete. Welding up the EGR still leaves a chance of leaking into your intake if it breaks, because fluid still goes thru it. With a delete it's not there,plus you get a new up pipe without the scope in it that causes turbulence in the exhaust.
Old 10-08-2016, 09:31 AM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
Do delete, keep the EGR valve leaving it plugged in and zip tied out of the way. You can run with the delete without throwing codes and eliminate the need run a tune to clear up the check engine light.
Old 10-08-2016, 09:34 AM
Per4mance's Avatar
Per4mance
That's not true, The IA2 sensor will pick it up and set a code giving a check engine light. Leaving the EGR valve in will keep the fan in check and functioning as it was. And you don't have to remove the valve.
Old 10-08-2016, 09:37 AM
duste's Avatar
duste
duste is offline
[QUOTE=1979 Ford;16630603]Do delete, keep the EGR valve leaving it plugged in and zip tied out of the way. You can run with the delete without throwing codes and eliminate the need run a tune to clear up the check engine light.[/QUOTE
I was wondering if this would work. I was going to try it to see, I have a delete kit here and may use it if I need a tune regardless. I have a Edge on it now but it does not do the egr delete light. I should just stick to build 77-79's . No computers to deal with.
Old 10-08-2016, 09:45 AM
duste's Avatar
duste
duste is offline
thanks , I have a delete kit here , I just wanted to get around buying another tuner just to get rid of a light. Why the IPR delete? never heard much on them but this is my first go round with a 6.0 . I prefer my 7.3 at this point. Haven't had to do anything other than rebuilding the turbo last summer.
Tideman's Avatar
Tideman
Tideman is offline
Per4mance is right. I Have an 06 it does throw a DTC and the check engine light will stay on without a tuner.
Old 10-08-2016, 09:46 AM
Per4mance's Avatar
Per4mance
Trust me, it will set a code. There's no need to remove the EGR. Some guys just do it because of the cool plate or what ever. It needs that valve plugged in due to the fact it is in the circuit some how. I'm doing a IPR delete right now on my F250 along with some other mods. The only one that you wouldn't need a tuner on is a 03 as it isn't programmed that way
Old 10-08-2016, 09:53 AM
Per4mance's Avatar
Per4mance
I have all IPR stuff in my truck,it's a little pricey,but I like the quality and the engineering that went into it.Yes I have gone a couple of rounds with Vince with him cheeping out on some things but all in all it's a really good product. I especially like the coolant filter,as you can just clean it.
Old 10-08-2016, 09:56 AM
run6.0run's Avatar
run6.0run
run6.0run is offline
Ipr is a crapchute. Might be good,, might not be. 90% of them were ok,,, but cast sux. I've got a stack of leaking ones that I've had to warranty.
Old 10-08-2016, 09:59 AM
Per4mance's Avatar
Per4mance
Did he ever make good on them yet? I was on the phone with him yesterday,same old Vince. I tried to call you,but you know how that goes.
duste's Avatar
duste
duste is offline
Well I guess I will go with the delete then, if I need another tuner regardless I would rather just get rid of it altogether. Thanks for the info.
Old 10-08-2016, 10:02 AM
Per4mance's Avatar
Per4mance
I run a Livewire TS,just because it is a monitor too. The bad side is if some bum steals it and you don't back up you strategy your screwed.
Old 10-08-2016, 02:40 PM
darrellbarnes's Avatar
darrellbarnes
darrellbarnes is offline
My early 05 has been deleted a couple of years and no code. I think 05 was hit and miss that way then 06-07 is a definite on the code.
Old 10-08-2016, 08:53 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
Installed the IPR delete with the new up pipe on my 6.0L last year. Been very happy with it. With this kit, FICM upgrade, fuel pressure spring and some other mods she's been just as dependable as my 7.3L's.
Quick Reply: EGR Delete's and tuners question.
