1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
how to do upper + lower ball joints 2012 f550 superduty 4x4 6.7 diesel
Old 09-28-2016, 07:00 PM
F-WhiteThunder's Avatar
F-WhiteThunder
F-WhiteThunder is offline
I need to do upper and lower ball joints on a 2012 ford f550 superduty 4x4 diesel. its a single cab with dually rear not sure if that matters. . I need procedure and torque specs and any special tools. I've done ball joints on my jeeps but not on a truck like this with all the 4x4 stuff. Thanks
Old 09-28-2016, 09:35 PM
dieselandmud's Avatar
dieselandmud
dieselandmud is offline
This will give an idea of what you need and how.
2004 F250 Ball Joint Replacement
Old 09-29-2016, 09:38 AM
F-WhiteThunder
thanks but how much is relevant to the 2012 model and on a bigger truck
Old 09-29-2016, 09:57 AM
shawn.snow's Avatar
shawn.snow
shawn.snow is offline
I don't have access to the specs for a 550 but for a 350 the torque specs are below and I attached the all data guide.
Lower 0-1.0 mm (0-0.04 in)
Upper 0-0.6 mm (0-0.024 in)
File Type: pdf
File Type: pdf
File Type: pdf
Old 09-29-2016, 10:24 AM
F-WhiteThunder
exactly lol Thanks yeah I've done some work on 2003 f550s but not 2012 and would need like to know procedure torque spec and recommended replacement parts like seals or whatever and if i need any special tools. it seems like most guys aren't doing this type of job on their own on this vehicle so I'd have to get lucky with a mechanic getting me the info
Old 09-29-2016, 11:24 AM
shawn.snow's Avatar
shawn.snow
looks like alldatadiy.com has the 550 manual if you plan to do most of the work on the truck yourself it may be worth the investment. 1 year subscription for 1 vehicle is 26.95 and 5 year is 44.95
Old 09-29-2016, 05:06 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
You need the seal driver for the 05+ and a long nose snap ring pliers.
Other than that just take it apart and put it back together.
Old 09-30-2016, 11:24 AM
F-WhiteThunder
seal driver has been on my mind also . any special ball joint adapters needed?
Old 09-30-2016, 11:28 PM
kjeffery's Avatar
kjeffery
kjeffery is offline
Have you gotten a quote on what a shop would charge you? It might be worth it to have it done in a day. You'll have to rent a ball joint press, perhaps buy special ball joints (Amazon doesn't sell anything over f-350, and with the f-550 10-lug semi tires, they might be too weak), power tools to make stuff quicker, a vacuum sealer (if it's vacuum-operated, don't know, 4 wheel drive might not engaged properly). Gonna have to have a grease gun, grease, they say an alignment (though you can get away without it), and a bunch of time on your hands. The moog ball joints come with directions and torque specs.
Old 10-03-2016, 08:01 AM
tfalk's Avatar
tfalk
tfalk is offline
Where are you in NJ? I just did the ball joints on my 06 and I have the seal installer. I rented the ball joint press from Advanced Auto, they have 2 kits, you need the set with more pieces. I also have the snap ring pliers needed.
Old 10-03-2016, 08:06 AM
The Bone's Avatar
The Bone
The Bone is offline
Only 4 years old and the ball joints are already bad? Seems like premature failure to me. Ball joints should last longer unless you run larger tires than stock or have the truck lifted. In ether case let your parts guy know and get the best ones you can get
Old 10-03-2016, 11:03 AM
r2millers's Avatar
r2millers
r2millers is offline
Huh?
Chris, you make it sound so easy. Review Shawn's spec pages of the parts needed and tools required.
Rent the c press from Autozone, don't bu the Harbor Freight unit that bends.
We used the freezer and heat to help the process, not to mention a sledge where required.
It's not a newbie project for those trying something new for the first time.
Many won't tackle this project unless they have a press.
Old 10-03-2016, 11:19 AM
MisterCMK's Avatar
MisterCMK
Originally Posted by r2millers
Huh?
I didn't find it to be that difficult. I live in MN, land of rust and salt and I didn't need a sledge for mine. A press isn't needed, but yes the ball joint tools are.
If somebody wants to try working on their truck for the first time, ball joints are pretty hard to screw up.
Old 10-07-2016, 05:47 PM
r2millers's Avatar
r2millers
Chris, now it sounds like changing oil and changing ball joints are both "beginner" type jobs.
If someone starts this job as a first timer, completing this job without help, could be a bigger challenge then first expected.
Maybe you're just that good at replacing these so easily, but I don't want anyone to get the opinion that it's a piece of cake kind of job, like an oil change, fuel filter change, or the like.
That just isn't the case.
Old 10-17-2016, 09:51 AM
MisterCMK's Avatar
MisterCMK
It still isn't rocket science....
rbfunk85
05-22-2023 03:13 PM
ymurf
13
05-12-2018 09:10 PM
Whitey Ford
05-09-2015 08:55 AM
gingerbreadmaniac
07-28-2005 02:03 AM
Quick Reply: how to do upper + lower ball joints 2012 f550 superduty 4x4 6.7 diesel
