Vin needing decoded
Q = 477 4V
U = Louisville KY Assembly Plant.
200012 = 1961 .. assembled August 1961.
153" Wheelbase.
COLOR: Blank.*
C850 Tilt Cab .. 27,000 lbs. GVWR
Date: Blank (not relevant after 1960).
TRANS: Pic is too glossy, cannot make out the code.
AXLE: Blank.*
27,000 lbs. Gross Vehicle Weight Rating.
222 net HP @ 3,200 RPM
450796:
45 = Davenport IA Ford District Sales Office, where the original selling dealer ordered the truck from.
0796 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*Domestic Special Orders: The truck was painted a non standard color, so there's no COLOR code. The rear axle was also a special order.
Please ask further questions in the LARGE TRUCK forum, most members of this forum have F100/350's, many are pickups.
Welcome to FTE fellow Canadian. I can't fully decode your Warrentee plate but I do know it was made in San Jose California and has a 352 engine short wheelbase and it was a special order due to the no colour code and a six digit dso. I believe it was sold new in Los Angeles and would have been made either in late December 1965 or January of 1966. I am guessing the interior was a beige colour if I remember the 481 key code from other posts. NumberDummy will correct all my errors and poke fun at me for trying.
Y = 352 2V
R = San Jose CA Assembly Plant.
803308 = 1966, assembled January 1966.
115" Wheelbase.
COLOR: Blank.*
F100 2WD .. 5,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
A8 = Dana 44 Rear Axle / 3.54-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
711334:
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
1334 = Domestic Special Order number, the truck was ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, the truck was painted a non standard color, making it a Domestic Special Order.
F10 = F100 2WD
Y = 352 2V
115" Wheelbase.
COLOR: Blank.*
711334:
Y = 352 2V
115" Wheelbase.
COLOR: Blank.*
711334:
Thank you!! I guess a few things have been changed. I thought it had the stock rear end but now I'm not so sure. I'll have to find a number on the axle to see what it is. Here is a picture of it and I'm thinking it's the standard 9"
Here's the parts catalog example of what a Dana rear axle looks like. Looks like your truck has a swapped in 9 inch, but...
Compare the VIN on the Warranty Plate (riveted to the left door face below the latch) to the VIN on the registration to see if they match, because...
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
Your truck was assembled in San Jose CA .. ordered from Los Angeles, sold new in SoCal...but it's now located in Ontario Canada, not Ontario California!
You can tell it's an FE of some sort just by the way the exhaust manifolds bolt on. The valve covers, while clearly aftermarket, are not Windsor because the end doesn't taper back but rather is at a 90 to the bottom. Think rectangular (FE) rather than trapezoidal (SBF/Windsor).
