Weather or water proofing and cleaning contacts
I already have a thread in electrical but hoping for more exposure here aswell.
https://www.ford-trucks.com/forums/1...nnections.html
Have you considered wrapping the wire bundle with self fusing silicone 'repair tape'?
As you stretch the tape it fuses with the last turn underneath it and in a day or so becomes all one piece.
I've used this stuff to repair condensate drains, replace the overmolded rubber grip on a nail gun and tightly bundle wires.
If you squirt some rtv between the wires at the beginning and end of your wrap, i don't think you could get a more hermetic seal.
I found one. PN: 3U2Z-14S411-NNA The only one I could find in the catalog. I need the 8 and 12 pin. Male and female. Matching wire colors would be even better. But really, I'll still have "exposed" connections. So I was wondering if anyone might know of a more suitable replacement. I still want to be able to pull them apart if I need to.
If I had to guess, 14. There is some bare spots on some wires, and they're just spinning around. IF, There was NO alternative, and if I took the time, I could probably rehab them. But until it comes to that, I'm looking for something more suitable or fit for the job. These are more like what you'd find in the cab.
Moisture (humidity) gets to copper after a while. Its very humid in Houston. And, I like all my electrical connections clean, tight, and sealed from any moisture to keep them working almost maintenance free. Even a ground I like to keep that way. I HATE chasing bad grounds. Done it to many times before.
