Another timing question...1984 f150
Was starting to install my new distributor and noticed I only had 1 set of timing marks. As you can see from the pics. I do have a the little scribe line and notch on the balancer. So do I set TDC from the driver side marks then?
Passenger Side
Driver Side
Passenger Side
Driver Side
Okay something I like to do is mark the mark on the balancer/pulley with a paint pen.
What makes the stabbing of the distributor annoying is the oil pump drive. You may have the distributor drop almost all the way where you want it but the oil pump drive will not line up. Pull your distributor out and stick something down there to move the drive a little and go from there..
rlh68050
08-17-2019 06:19 PM
sgauvry
07-29-2015 05:28 PM
dogmantra
10-04-2010 12:43 AM
btacarlton
28
04-17-2009 09:40 AM
