6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Blow by?
Old 09-25-2016, 09:09 AM
redz284u's Avatar
redz284u
redz284u is offline
Blow by?
How much blown by is too much. I have some coming out the oil dipstick tube. I was on the road, and decided to check it, while engine running, and there was smoke coming out of it as soon as I took the dip stick out. So I unscrewed the oil filler cap, and there was a lot more from there. I know some amount is ok, but the amount of smoke from both places has me concerned.
How do you measure how much is too much? How do you measure it?
Old 09-25-2016, 11:23 AM
eberlestock's Avatar
eberlestock
eberlestock is offline
Unscrew your oil cap and then just set it over the hole with motor running. If it blows it off the hole its too much blowby. My has a bit of smoke out the whole but doesn't blow the cap off.
Old 09-26-2016, 08:49 PM
redz284u's Avatar
redz284u
redz284u is offline
Old 09-28-2016, 06:03 PM
slowmans's Avatar
slowmans
slowmans is offline
How many miles on the truck?
Old 09-28-2016, 06:18 PM
redz284u's Avatar
redz284u
redz284u is offline
It's currently at 95000
Old 09-28-2016, 07:04 PM
slowmans's Avatar
slowmans
slowmans is offline
How much oil do you have to add between oil changes?
Old 09-28-2016, 07:41 PM
redz284u's Avatar
redz284u
redz284u is offline
Added new video of cap on fill hole, unscrewed
No oil added between oil changes. Most of time if a tiny bit higher than the max line
Collision
05-12-2016 01:01 PM
s2gots
17
11-24-2011 08:10 AM
3wildboys
25
11-08-2011 05:43 AM
Copedawg
01-07-2011 02:17 PM
Izzy351
42
04-07-2009 05:23 PM
Quick Reply: Blow by?
