Engine ID Number and Man Trans Conversion
A few months back I bought a 1994 F350 Dually which came from the factory with a 7.3l Turbo IDI engine and has a E4OD automatic. The transmission failed and with prior experience in the past with these transmissions want to convert it to a 5 speed manual transmission. One of the problems I am having is that the turbo motor I was told went bad and they put a non turbo motor (supposedly) in it's place. I found that there is a difference according to the parts stores between the flywheel on a turbo motor and a non-turbo. Can anyone tell me if the engine has an ID code on the block so that I can tell whether it is a turbo motor or not. The VIN number shows K which is a turbo motor that was installed in the factory. If there is no difference between a non-turbo motor and a turbo motor, let me know. Also, has anyone ever had any trouble converting an automatic truck to a manual transmission?
Thanks
Thanks
ive also heard that a true turbo engine has better valves.
parts from the N/A will bolt up to the turbo block.
be careful what you use.
the engine ID # is on the driversside next to the IP gear cover.
I believe, not 100% sure than N/A applications will have a U in the number, and turbo engines will have a T
I found the number and it is 69L F149211, there are two other number on the pad also, they are 133 and 695. I think I have a 6.9l in my truck but can anyone here tell me if this is true for sure. I have to know what size engine was put in my truck before I bought it so I can get the right clutch kit. It was swapped prior to me purchasing it. They said it was a 7.3l w/o turbo but I am not sure.
Ok, I definitely have a 6.9l, here is the problem that I may have. I just got a 5 speed manual transmission in and I have to find a clutch that will fit the 6.9l and also match up to the transmission. Will a 7.3l non turbo clutch and flywheel fit the crank on the 6.9l and will the ring gear match up with the starter.
So most everyone upgrades to a SMF - single mass flywheel.
You should be able to get a SMF kit for 6.9, 7.3 or 7.3 turbo, each of which should be balanced differently.
You /need/ a 6.9 flywheel and pressure plate, and a 7.3 clutch disk for the ZF-5
Hopefully you can contact Luk or South Bend and get them to sell you a 6.9 kit without the disk, and a separate disk of the same size with the correct spline.
edit:
as far as I can tell.
LuK has a 6.9 clutch set(pressure plate + disk): PN 07-065. Not sure about the flywheel.
They have a 7.3/5-speed smf clutch set: PN 07-131
#07-225 includes a 7.3 flywheel.
So... as far as I can tell, you may be able to run a 7.3 non-turbo smf clutch and flywheel on your 6.9. I am not going to recommend it as I don't know what will happen if it's balanced too far off.
It will fit, however, and I've seen a number of people doing this on various forums.
I'd like someone else to chime in if it is OK. You might end up with a little more vibration... not that the 6.9/7.3 doesn't vibrate pretty badly anyway!
