Leaf spring rebuild parts
Old 09-09-2016, 06:00 PM
fightlivefree's Avatar
fightlivefree
fightlivefree is offline
I have a 92 F150, XLT 302 cu in, 4WD.
My hangers were disintegrating so I bought all new hangers for the leaf springs and I figured I would buy new leaf springs too. But the question is should I buy new parts that go under the leaf spring and attach it to the axle (U-bolts, spacers,etc) What are these parts called?
I was wondering if these parts under the leaf spring get fatigued or not.
Regards,
Larry
Old 09-10-2016, 12:45 AM
Big_Al59's Avatar
Big_Al59
Big_Al59 is offline
I've always thought it was a good idea to install new u bolts with new springs. Not that expensive.
Old 09-10-2016, 11:40 AM
fightlivefree
They're called Shackles
Thanks Big_A159. I think I will follow your advice.
Regards,
Larry
Old 09-10-2016, 02:16 PM
arse_sidewards's Avatar
arse_sidewards
arse_sidewards is offline
Regards,
Larry
They're not torqued to yield so there's technically no reason to do so. The vast majority of problems with U bolts come from people not torquing them down properly in one way or another. Setting the impact to kill and going around once isn't proper even if you can get away with it.
Replace the U bolts if it helps you sleep better at night.
Old 09-10-2016, 04:55 PM
fightlivefree
I-bolts/spacer
Yeah, you're probably right, but the problem is I can't find anybody who sells replacement parts. I tried doorman and they don't seem to make them. I tried a few other places to no avail. If they're cheap and available I'll replace them.
Regards,
Larry
Old 09-10-2016, 05:59 PM
arse_sidewards
Regards,
Larry
U bolts are usually sold by dimension, not application. Measure your U bolts. IIRC the tube is 3-1/2" and the thread is 1/2-20 fine thread.
Old 09-10-2016, 06:28 PM
Wheelman55's Avatar
Wheelman55
Wheelman55 is offline
Try these guys. I got replacement u-bolts for my Ride-rite airbags from them.
U-Bolts, Leaf Spring UBolts for Truck Suspension
Old 09-10-2016, 06:33 PM
fightlivefree
U-bolts
OK, will do. I guess I can keep the spacer between the axle and the leaf spring.
Regards,
Larry
Old 09-10-2016, 06:35 PM
fightlivefree
U-Bolds
Hey, Wheelman55, thanks a lot.
I will order some from the link.
I'm restoring my truck one part at a time.....
Regards,
Larry
Old 09-10-2016, 06:52 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,360 Likes on 1,074 Posts
Regards,
Larry
I'm a bit confused. You bought new "hangers"? By hangers you mean the frame brackets or shackles?
Then you want to know if you should buy new parts that go under/attach the axle to the spring (shims and u-bolts) and then ask if that is what they are called? Yes the u-bolts hold the axle to the spring. Your title in post #3 says they are called shackles. What is called shackles? That is not what hold the axle to the spring but then thank Big Al for his answer. Shackles hold the spring eye to the spring hanger.
Sorry but I'm just trying to figure out what you are asking.
Old 09-10-2016, 08:28 PM
fightlivefree
Leaf spring hangers/supports/fittings
My4Fordtrucks, by hangers, that's what all the part stores call the sheet metal fittings that attach the leaf spring end bolts to the (hangers or mounts or frame brackets) that are attached to the frame bed.
I guess You call them "Frame brackets." Now the funny thing is there is a shackle that is inside the hangers (frame brackets) on the rear of my leaf spring so I help that helps. This confused me too until I saw what people were talking about. If I was to name that part I would call it a clevis of some sort. Maybe a frame support clevis. haha. I dunno.
On the parts below the leaf spring (in the middle generally) they have some U-bolts and a spacer. Sorry, if I was calling them shackles too. It's confusing, I think of hand cuffs as shackles too.
Regards,
Larry
Old 09-11-2016, 04:26 AM
My4Fordtrucks
Regards,
Larry
I did not call the shackles "frame brackets". I was asking you what you were referring to when you said hangers. I had not heard of shackles being called "hangers" which is why I was asking. In this response you are calling both the shackles and bracket as hangers which is why I was asking for clarification on what you replaced. Hope this picture helps you with terminology
Old 09-11-2016, 03:24 PM
fightlivefree
Your picture shows what I am saying. I bought the hangers (4 on picture) Some people call them mounts. I don't want to start a argument where none existed. And yes the part 6 is called a shackle as named in the picture. That's what I called it.
I guess I don't know what you refer to as "Frame Bracket". I don't see it on the picture. Are you saying they are the same as 4?
I admit I called the U-bolts assembly (9,7,8) = shackles. Mea culpa, Mea culpa...
Larry
underthebridgejim
01-10-2015 04:50 PM
okedokeno
04-28-2012 01:12 PM
cabloom300
09-07-2009 01:49 AM
Paul4545
02-09-2007 12:57 PM
imsorope
1983 - 2012 Ranger & B-Series
02-18-2004 10:17 PM
Quick Reply: Leaf spring rebuild parts
