92-93 versus 94-95 Gauges and Clusters
My 94 has the factory tach instrument cluster. I have a 93 Lightning instrument cluster that I would like to use. I know that there are some differences between 92-93 and 94-95 instrument clusters. I believe this is mostly due to the air bag and the volt meter. Anyway rather than attempt to modify the cluster to work, would it be a better idea to install the speedometer and tach from the 93 Lightning cluster into the 94 cluster leaving the gauges on the left from the 94 in place?
I installed a 94 Lightning cluster in my old 95, and I believe that raised the speed limiter somehow, because I had it going much faster than the factory limiter. The main reason I want to switch it, is because it's a very cool piece, and I hate looking at a pegged out speedometer while driving at 80 mph which is a common speed here.
When you swap the PSOM, make sure you recal the PSOM for your vehicle, your your speedo and odo could be off.
As for the gauges themselves, they appear to be pin compatible with different year clusters, BUT the indicator lights will be in different places. I have checked this out a few years ago and forgotten which was different when I swapped a F-series tach cluster into my E-series van. As for my E350, I went and repined the harness for the F-series cluster, added the tach wire to ignition coil tach side and had no issues(PSOM different story)
