An oil leak question
thank you for opening my thread
Ok, I am currently in the market for a 1995-1997 F350 7.3, CC, auto, LB 4x4. I live in the California Bay Area and these rigs are becoming VERY hard to find. The few I have looked at ALL leak a boatload of oil when parked. And I dont want to deal with cleaning my and other peoples driveways.
Do ALL these years 7.3's leak oil like this?
the dipstick to oil pan seal is known to leak and can be fixed with out dropping the pan
other leaks just need to be found
If there is a fuel leak, it will look like an oil leak as it cleans out the valley and dips off back of motor
many people cant afford taking to a shop to fix these leaks
Ok, I am currently in the market for a 1995-1997 F350 7.3, CC, auto, LB 4x4. I live in the California Bay Area and these rigs are becoming VERY hard to find. The few I have looked at ALL leak a boatload of oil when parked. And I dont want to deal with clean my and other peoples driveways.
The big issues are people are stupid and just run stuff untill it falls apart then buy another .
If you have the time, money and tools, you can get the leaks to stop.
Thanks, it took me a while to find that on Craigslist and the person never posted a pic online. I saw his ad for a few weeks and decided why not ask. Then once I saw it, I pounced on it. I found a for sale sign in the back seat the other night. Didn't know the center flipped down. it was listed at 10k at one point in time in past 3 years. Also it was from AZ and not rusty at all. Hasn't seen much road salt.
Ultimate Automotive Leak Detector
You have leaks you want to know were they are. This is good for finding oil leaks gas leaks antifreeze leeks vacuum leaks rear end seal leaks and you can add dye and locate a pin hole in a vacuum line or any other leak you name it power steering unit and lines. This leak detector is the best in its class of leak detectors.
Finding Leaks
Want to know a way to locate a leak in seconds and it works every were every time oil antifreeze gear oil gas transmission vacuum line leaks you name it real easy to locate. And fast. Just click on the name Ultimate above and on profile page click on pitcher to right of page for full description and plenty working pitchers. Better boss
__________________
1johnnylovesy@gmail.com
__________________
What is this "SD" you speak of? I know not what you speak of. I just assumed for quit making good trucks after 1997 !?!?
Received 3,701 Likes
on
97 160,000 miles no leaks
'95 150,000 miles oil pan has slight leak
'99 340,000 miles no leaks
2000 202,000 miles no leaks
as stated stay on top of maintenance I will park everything but the '95 on a brick driveway and not worry about oil stains.
on
