2016 F350 DRW axle leak
So got to a job this afternoon and smelled a grease smell by the rear of the truck. Got under it and saw some black liquid accumulated on the rear passenger side backing plate behind the rotor. But it didn't really have a smell, certainly didn't smell like gear oil.. But it doesn't appear to be brake fluid either.. I blew in the diff breather hose and it's not clogged (5k miles on truck, shouldn't be clogged yet).
When I got home, I didn't smell it anymore and it didn't appear to be anymore accumulation than before. I'm gonna keep an eye on it for the next few days.
Any ideas? Seems like it has to be gear oil from a leaking hub seal, but just thought it was odd that it didn't smell like gear oil.
I had a seal blow in my truck and I didnt find any oil in a puddle but notices it on the rim of the rear tire, when I took the tire off I could see that the brake was contaminated with oil and it was not brake fluid. I then knew a seal went and started the job of repairing it.
I would keep an eye on it liked you planned, lord knows you wouldnt want to lose fluid out of the rear end
I would gather you are under warranty, so I would take it to the dealer and let them know what you found and ask them to check the diff, they should do it at no charge I would think, better to be safe then sorry
Square Grouper
1999 to 2016 Super Duty
27
10-06-2016 05:53 PM
jagarcia89
2004 - 2008 F150
22
04-26-2012 08:59 PM
padd54
22
05-27-2005 01:43 AM
