Name and Part Number Help
I am looking for the proper name and part number for the 1-1/2" hex x 3/4" square socket adapter for removing the inner lug on 1-1/2 ton rear axle duals. I'll post a want ad once I have the info. Thanks. I did not know such a thing existed until I helped remove wheels from a friend's 1935 and an old pro showed up with the tool.
After looking at the J part in the picture. It looks like one end is for the hex nut and the other end is for the square nut on the stud.
http://www.ebay.com/itm/Vintage-FOMO...-/121557222034
Brian, how does that tool work?
Tacoma, the ebay listing is indeed "J". The seller should post the two sizes for people to be sure..
Here are pictures of the tool(s) I received with the fire engine. I need about a 4' pipe for the rod to get enough leverage to remove the nuts. Guess I should just do that and save some money.
Does anyone know the tightening torque specs?
1-1/2" hex for the lug nuts
13/16" square end for the Budd inner lugs
J does have the square socket in the end opposite the hex end. I have the tools for my '49 F4 and it is the same wrench. The '49 tools have a longer straight handle for the wheel nut socket and a separate tire iron that is double ended. IIRC the wheel nuts are torqued at 450 ft. lbs.
Mark
Mark
Very good! You will have to support the outboard end of the wrench so that the force passes through its pivot point.
the way it works is the inner tube has a 13/16 socket. it holes the 13/16 (bottle thats what my dad called it)square nut. while the exterior one is 1 1/2 inch and spins around it. it prevents the bottle from releasing before the nut. and acts as a multiplier for less effort. often when you remove the outter tire the whole nut and bottle comes together,and you would have to torch it off. hope it sounds right.
maybe read this its explained better.
Ken Tool 40543 Budd Wheel Power Wrench Set | Uncle Sam's Retail Outlet
The older gentleman who had the 1-1/2" hex by 13/16" square socket adapter mentioned the tool. Thanks for the info; I found the product info and instructions at KenTool.com: Power Wrench : Power Wrench Sets. The knowledge and helpfulness on FTE is just amazing.
