steering column bearing change question
I'm putting the column back together after changing the 2 upper bearings. When I installed the spring and snap ring there is very little pressure on the spring, I can easily turn the spring with 2 fingers. Does anybody that has done this remember how much the spring should be compressed? This is with a new spring.
xrsfsho, you were right about having the snap ring in the wrong groove. when I put the directional signal canceling block on and it was way to high I realized the ring had to go on lower. I never thought the lower position was a snap ring groove because somehow it wore to a groove almost 1/4 " wide. Thanks for your help.
hivolt5.0
03-05-2009 05:53 PM
galanthias
03-21-2005 09:44 PM
