Biggest injectors before heaDstuds
What Adam said. It pretty much depends on boost. If you want to run 40 psi with large injectors you should stud it. If you run 250/200 injectors but only run 35 psi boost then it's up to you. Most won't run the studs in the 7.3 till 40 or above. We have a lot of head bolts unlike the 6.0 6.4 guys.
Since this is a recent thing for me - I can say you have to really want it. They start at about $550 and go up from there - I think they are "on sale" right now at Riffraff Diesel. Once you have the box with yellow tape, you have to man-handle 72 bolts. Break loose and remove 36, and install and torque 36 bolts to 125 ft/lbs. This is all done one bolt out and one in at a time, but you also have to clean the threads. All this while leaning over the fenders - break out the Ben Gay.
40 PSI is the magic number (according to all my sources), but if you are looking behind that particular curtain - valve springs, shims, seals, and pushrods will be in the same box with yellow tape. I didn't have to speculate on the springs, it's a matter of math.
Originally Posted by Tugly
Since this is a recent thing for me - I can say you have to really want it. They start at about $550 and go up from there - I think they are "on sale" right now at Riffraff Diesel. Once you have the box with yellow tape, you have to man-handle 76 bolts. Break loose and remove 36, and install and torque 36 bolts to 125 ft/lbs. This is all done one bolt out and one in at a time, but you also have to clean the threads. All this while leaning over the fenders - break out the Ben Gay.
40 PSI is the magic number (according to all my sources), but if you are looking behind that particular curtain - valve springs, shims, and pushrods will be in the same box with yellow tape. I didn't have to speculate on the springs, it's a matter of math.
You might as well pull the engine out, reseal everything things like the oil pan, front cover, oil cooler, install the fuel system you'll definitely need, Install the studs, and do the valve springs as well.
The 7.3 is a deceptively strong engine that can handle some power, but you do have to upgrade a few things if you're wanting to go with considerably larger sticks. 160/stock, 160/30, 160/100, you can getaway without upgrading too much, but beyond that, I'd do some future proofing.
I see what you did there.
To the OP, as others have said you need to take a holistic approach. Look at the weakest link in your system and run accordingly. For instance, my turbo system will run 45psi all day long but I currently have a 6.0 intercooler with plastic end tanks so i have limited boost to 35psi.
