Clutch stuck
Welcome to FTE!
Check the linkage from the peddle to the cylinder. Push rod may have broke or the clip that holds it may have popped off. If that looks good then check cylinder fluid and check for leaks around the cylinder and transmission, you may have lost pressure. If that looks good you may have a bad slave cylinder
RenoHuskerDu
10-04-2020 12:41 AM
jamesobush
11-24-2009 12:38 AM
