passing along our "wisdom" to the next generations
Old 08-17-2016, 07:44 PM
r_reed's Avatar
r_reed
r_reed is offline
my grandson was helping me with an oil change in my F1. he held the funnel while i wrestled the jug of oil under the hood. he said do, you have to measure it? no, it takes 4 quarts. finish up, check the oil and it's way over. oops, jug was a 5 gallon jug. proceeded to show him how to open the oil drain and let enough to get it back down to 4 quarts. hope he learned something from that. all good.
Old 08-17-2016, 09:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
???? Your truck should take 5 qts ??? What markings are on your dipstick, right around the Full mark? Are you running a truck oil pan?
Good for you getting the boy involved! It may come back to bite you, LOL
Old 08-17-2016, 10:16 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
I don't know oil capacities' but I do know something about memories I treasure every memory of my grandfather. I'm sure your grand son will not only remember the day, but treasure it as well.
Old 08-17-2016, 11:01 PM
pweng1's Avatar
pweng1
pweng1 is offline
I really think its important to pass our knowledge and hobbies on to the next generation.
I see the pride in my sons eyes when somethings hard and they finally get it done. I remember when transporting my grill to a cookout we lost a bracket for it and i was mad. My son said why you upset that is easy to make and in 5 mins he was done. Priceless
Old 08-18-2016, 08:16 AM
tnunisaw's Avatar
tnunisaw
tnunisaw is offline
Best of all, Just thank the lord you have a grandson to share it with. Some of us can only wish we had.
Old 08-18-2016, 07:24 PM
CBeav's Avatar
CBeav
CBeav is offline
Agree with all. And I wish I had a grandson or two! (pretty much just me around here)
I remember my first 'real' mechanical experience... my grandparents had a farm and my grandfather had just repaired a flat tire for one of the hay wagons and told me to put it on the wagon. I placed it on the hub and began putting the lug nuts on with the cones facing out. My Uncle Paul walked by, watched me for a moment and asked, "They look better that way, don't they?" He then explained the purpose of them being installed with the cones in. I didn't realize it until many years later how he took the time to figure out why I was doing it the way I was. So, in his own way, he had given me two lessons for the price of one.
Old 08-19-2016, 12:30 AM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
When I was quite young (9 or 10 yrs old), my Dad was putting the pistons into the block of his '54 Oldsmobile. He was doing a ring job with the block still in the car.
He asked me to lay under the car and guide the con rods past the crankshaft while he was pushing the pistons down into the cylinder bores. It was my first auto work.
He also did woodworking and got me into his shop often to help.
My two main interests/hobbies are woodworking and automobile. I owe it all to my Dad.
...Terry
Old 08-19-2016, 07:45 PM
r_reed's Avatar
r_reed
r_reed is offline
my engine is a '53 EAB car engine, with original oil pan, orig dip stick. i'm quite sure the capacity is 4 quarts plus whatever goes in the filter. my first real auto exp was when my father assisted my friend and i do a valve job on a flat 6 , 1950 plymouth. we were 16, he took the head bolts out, we took the valves out, took them to a garage to have them reground. replaced 4 valves, put them back then dad torqued down the head. he advised us, we did some work during the day, he helped us at night. the car ran great until my friend clipped the back corner of a semi-trailer with it.
Last edited by r_reed; 08-19-2016 at 09:38 PM. Reason: corrected mistake as pointed out by stubbfarmer, thanks
Old 08-19-2016, 08:08 PM
toby tough's Avatar
toby tough
toby tough is offline
When my son was 4 I had him help me change the oil in the riding mower. We used my little adjustable wrench to pull the plug and drain the oil. The next day after work I hopped on and was going to mow and noticed the wrench laying on the running board. Picked it up and stuck it in my back pocket. About half way through the mow the engine seized. Couldn't figure out why till I noticed the oil plug was gone. The little guy must have been wrenchin' while I was at work. Kind of glad too cuz I didn't really like that mower much.
Old 08-19-2016, 08:43 PM
stubbfarmer's Avatar
stubbfarmer
stubbfarmer is offline
Originally Posted by r_reed
my engine is a '53 EAB car engine, with original oil pan, orig dip stick. i'm quite sure the capacity is 4 gallons plus whatever goes in the filter. my first real auto exp was when my father assisted my friend and i do a valve job on a flat 6 , 1950 plymouth. we were 16, he took the head bolts out, we took the valves out, took them to a garage to have them reground. replaced 4 valves, put them back then dad torqued down the head. he advised us, we did some work during the day, he helped us at night. the car ran great until my friend clipped the back corner of a semi-trailer with it.
4 gallons would be 16 quarts. That seems like 3 or 4 oil changes to me.
Old 08-19-2016, 08:46 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
A little knowledge can be a dangerous thing!
That is a great story!
Old 08-21-2016, 10:11 AM
Ibuildmyown's Avatar
Ibuildmyown
Ibuildmyown is offline
My oldest grandson 14
my next grandson 12
Teaching them young about body and paint work on old iron . 1965 scout hood for a friend of mine.
Old 08-21-2016, 01:29 PM
r_reed's Avatar
r_reed
r_reed is offline
ibuildmyown, very nice, we will always need autobody techs as long as people smash up cars. a good career choice or hobby.
evan_nugget
04-06-2018 06:36 AM
Bohen
6.7L Power Stroke Diesel
08-31-2017 07:31 AM
robandrosco
6.2L V8
02-20-2017 11:52 AM
muns53
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-17-2011 11:56 AM
Miguy
03-25-2009 06:49 AM
Quick Reply: passing along our "wisdom" to the next generations
