Saturn electric power steering in a Slick?
Has anyone done this successfully? I'd like to give it a try at that price.
$100 Power Steering? Yes you can. Use Column Electric Power Assist System (EPAS) ! - Page 2 - Ford Muscle Forums : Ford Muscle Cars Tech Forum
Sounds like a reasonable option that I would like to hear more about. Here is another write up about it: Best $200 mod ever (EPS). - Page 7 - Vintage Mustang Forums
Here is the controller box harness. Saturn Vue ion Chevrolet Equinox ? Electric Power Steering Controller Box ? Epas | eBay
Or available here stateside: http://epowersteering.com/index.html#services-section
I have a complete setup along with a pair of adjustable control modules you can buy from a guy in the Ukraine (or some such place - Mustang owner purchased them). Was going to install it into a '69 Mustang I was building. With all that was under that dash and the narrow space between the dash and firewall, it was deemed a bit too much work compared to just adding a Borgeson unit, which was the direction we went. So I inherited the pile.
My plans are to put it into my '63 Ranchero... someday. A lot more room under its dash. My '66 F100 already has power steering.
You'll have to do a lot of "joint fusion" to get double-d's onto it and then to get the correct steering wheel shaft applied, but probably won't be too hard.
Edit... My bad... Portugal: http://www.ebay.com/itm/Saturn-Vue-I...lRcSCy&vxp=mtr
It appears there is no room under the dash, at least when there is a clutch pedal there, but there is just enough shaft under the hood that could be removed and replaced with the motor. The inner fender will have to be cut for clearance though. I'm a little behind because the '06 motor I bought turned out to be a '09 which will not work with the aftermarket controller, and the replacement I got is water damaged and NFG. I'm getting pretty good at removing these things now.
Incidentally, the "15 minute removal" estimate in the video is wildly optimistic especially if you don't carry the 7mm nutdriver required to get the dash apart.
Eric
Eric
klrdavep
01-29-2012 04:16 PM
RobPStroker
08-13-2006 02:18 AM
