Advice on 6V vs 12V?
#31
#32
Old school 50s and 60s examples, even used, would be better than any modern reproduction. The track record of el-cheapo electrical parts is not good and this is no place to skimp.
One suggestion I've heard that makes sense, (if there's still a motor repair shop in your area) is drop both the regulator and generator off together and let them handle it, they can spool up the generator and adjust voltage and current regulation and the rest of it to spec just to be sure.
Six volt generators from the usual suspects aren't cheap, but a lot of that price is for convenience if nothing else. Generators are just barely a step above stone knives and bearskins, you should be able to pick up a couple used carcasses cheap online or locally and rebuild them yourself. Remember everybody modifies to take alternators. Once they are setup right they seem to last pretty good, I was never told they were a problem so I never worried about it, and never really had any. I replaced one after 25k miles and the brushes looked like they had plenty of life left.
The regulator is key though, and also to make sure everything has good solid grounds. Running Halogens and they work fine, and my night vision isn't what it used to be.
#33
You have this option available (not sayin' you have to get this one) from many sources, and it eliminates the voltage regulator issue altogether.
6 Volt Alternator | eBay
PS: There is one listed for $55.
#34
Thanks a lot for all the great info Tedster.
I need to spend a few days researching options:
1. Test regulator and rebuild generator. (doesn't look like there's any electric motor shops near me willing to do anything non-industrial)
2. Do the full 12V conversion, put my 12v battery back in and ditch the 6v
3. 6V alternator (thanks MixerMan, didn't even know that was an option)
#35
#36
There's a great shop up here in Williamsport. Hovey's Auto Electrical Services.
The place is kind of old but that guy is old time good! He prefer's your "old" regulator instead of getting a new one. Took my 6V starters (2 of them) and 6V generators(2 of them) and my original regulators. Rebuilt all of them and painted the casings (asked first but I said definitely). I think the total bill was $280 or so and these are like NOS now.
#37
#38
I found a place in the Collegeville area called "Trappe Auto Electric" willing to do the work.
Sounds like it's going to be ~$200 to get the gen and reg back up to snuff.
I am going to take the weekend to think about this option vs. carrying out the 12V conversion.
Thanks for all the advice
#39
I think it will largely depend on how stock and original you want to keep the truck. I was at the same threshold with the mixer truck, but knowing that I could improve the reliability while at the same time add more functionality and amenities (electric air compressor and vacuum pumps, linear actuators for the mixer, air ride seat, etc) by going with an updated 12 volt system. I wanted to keep it as stock and original as possible, but the engineer inside me just couldn't leave it alone. That's my story. Pics 'n stuff in my albums.
#40
#41
My advice on 6 or 12 volt? If you plan on a stock simple truck without a lot of accessories, stereo, air conditioning, etc, 6 volt will serve you fine if you have the proper size cables and the ends are clean and bright. Both my trucks are 6 volt.
#42
#43
#44
