Help....Rolling Coal and don't want to
Many of us with exhaust or intake leaks have experienced soot out the pipe with stock tuning... it just took me a while to get here. Air in/out leak is suspect #1, complete with a "Most Wanted" poster. I would issue a BOLO and grab a light, mirror, Simple Green, and some plumbing parts with an air fitting.
OK-- Start over with the basics. Soon as I have a day off I'll break out the boost leak detector, check manifolds, uppies and any place I could be losing air.
Will set AE for above pids and go for a run, Watching boost gauge for lag. How quickly should a stock turbo with billet wheel start responding to throttle?
I went back and looked at Map pressures from some runs back 2014 and they look almost identical. Will try to get some decent runs logged so you guys can look at them for me.
Thanks for looking in and helping me get this sorted out, paul
So I've only had time to use the boost leak detector and take a close look at the uppies and manifolds. Put 25 psi on it and no leaks other than just a few bubbles of leak check where the red and green waste gate control lines go into the rubber adapters, very minor. No soot or leaks found.
Question about the turbo-- I used to shut the engine off and hear the turbo spin down for a while. Now I shut it off and the turbo spools down almost immediately. I checked it by hand and it feels smooth but when spun by hand only makes a couple of revolutions and stops. No real play in/ out or up/ down or side to side. No drag marks or unusual sounds. no oil leaking. Can it be bad and not exhibit any of the usual signs??
Should it spin more freely? does it matter if the oil is cold or at operating temp? Is it normal to feel a little resistance? I confess I know nothing about turbos except what I've learned here and read. Hands on experience is little or nothing.
Still plan to do some logging runs on my off days. Went for another quick run after leak checking and it seems to be black smoking more at acceleration.
While I know this is not the case here, but that picture got me thinking. I was remembering something last night - something that struck me while watching the original "Rambo":
Rambo is being chased by the officials and he finds himself in a dark mine. He happens upon a lantern and he shakes it to see if it has fuel, but it's empty and he smashes it on the ground. He finds another lantern, then repeats the full process. He stumbles onto some fuel, so he rips some fabric and wraps it around a stick to make a torch - then he applies fuel to the fabric and lights it.
Intentionally rolling coal reminds me of that scene: It's a macho and dramatic show for the audience - but the audience just might be thinking "Well... that was stupid."
Not disagreeing with you at all. But with the Ford AIS intake he shouldn't really be hearing much at all- especially unloaded (not towing). Don't ya think?
In relation to your turbo wheel spinning. If memory serves me right my turbo wheel spins freely with a manual turn of my hand. I would say it goes around 8ish times... This is from memory from 8 months ago though when I rebuilt it.
Subscribed to see where this goes.
I just went multiple rounds with my Cummins. I was complaining to my tuner how smokey it was with my tow mirrors down.
It turns out my map sensor was junk. For whatever reason my truck was seeing 35-36 psi of boost at in idle in park!! Therefore when I go on it at all the truck would dump TONS of fuel because it thought it needed to. I got that all straightened out after 2 weeks. Mechanically everything is sound with my truck... stupid awesome electrical.
Start from the beginning be sure to make sure everything is in order. Obviously you're not dealing with a typical problem and I'm very curious to know what it turns out to be.
I almost wonder what the exhaust side of the turbo looks like and wonder if that could come into play with what you're describing
That's a misconception brought forward by Powerstroke and duramax guys. For cruising tow mirrors down for performance and towing tow mirrors up
#28
One of my best friends has an 09, bone stock. Even he hates the way some of the kids treat their Dodges. He actually did the delete a couple years ago, and was shocked at how much it smoked, and more importantly, how loud it was. The first time he drove it home, his wife complained about how loud it was. Said she could hear him a half mile away. Told him there was no way she was going to ride in a truck that sounds like a hillbillies truck. (that threat alone would have been enough for me to keep it that way myself) So, he re-installed everything back to stock.
#29
So I spoke with Clay at Riff Raff. He could have tried to sell me parts but was his usual honest self. He says a cold turbo with residual oil in the bearings will have oil drag and probably only spin 1 to 2 revolutions when spun by hand. Off next couple of days so should be able to do some data logging
#30
Warm her up and give it a whirl... but I expect it will be the same. Listening to the video my impression is the turbo spools up too slow and down too fast. My guess is the shaft is binding for some reason. It spins, but with greater than normal resistance. Oil roasted on there or something? No experience to share on that, just throwing out a guess to explain what I think I heard.
