Stock Axle safety note
I was installing my shocks and decided to check the axle u-bolts. I had heard to check them for tightness on here before.
Well, two bolts were only finger tight
Just about every bolt needed some tightening. So be sure to check them out on a regular basis.
On another note. If you remove your shock mount bolts as you are cleaning your frame. Put them on before you put all the sheet metal on.
It would have been so much easier before I had everything on. Oh, well I got them on and the shocks installed. Now I need to find time to go for a drive.
fordman19762003
2009 - 2014 F150
06-30-2016 10:28 AM
gbroehl1
12-09-2006 06:48 AM
dgpruitt
02-08-2004 11:02 PM
