Volare torsion bar bushings
Old 07-28-2016, 03:03 PM
raerjim's Avatar
raerjim
raerjim is offline
Has anyone on here changed T-bar bushings? I'm wondering if it is a job better performed with the truck on a lift, or can it be done with the truck on Jack stands. I have the new bushings. Inner and outer. 56-BW??
Old 07-29-2016, 01:29 AM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
I pulled the bars off and did it. You can pull the bars on jack stands.
Old 07-29-2016, 06:22 AM
raerjim's Avatar
raerjim
raerjim is offline
truckeemtnfords, can you briefly explain how you dealt with removing the "keepers" on the outboard ends of the bars ? I understand there are some pins? that have to be ground out? Thanx for response.
Old 07-29-2016, 06:24 AM
raerjim's Avatar
raerjim
raerjim is offline
Dave, in your opinion, handling aside, did the truck steer differently after the work was done? Is an alignment required afterward?
Old 07-29-2016, 07:52 PM
truckeemtnfords
First off it has been years since I did mine but I will look at them in the morning to refresh my memory. As far as alignment, with the price of tires I would definitely get an alignment. As far as riding/working better I did all the work before I ever drove with the new front end.
Old 07-30-2016, 05:38 AM
raerjim's Avatar
raerjim
raerjim is offline
Great. What's the temp in Truckee this morning?
Old 07-30-2016, 07:05 PM
truckeemtnfords
Jim,
I get up late Saturdays because I work graveyards and it is my Monday but we have had the warmest last two nights/mornings that I can remember. The wife said it was 57 deg at 8am and that would have been typically been mid 40's on a good day.
I just got a chance to look at the front end and I replaced the factory pin (what ever that was, long time ago) with a grade 8 bolt and crimp locking nut (also called steel top, deformed thread and cone top lock nut, not a nylock. You get the idea). Hope that helps. If you have any other questions let me know.
Dave
Old 07-31-2016, 06:18 AM
raerjim's Avatar
raerjim
raerjim is offline
I am in SW florida, in the wintertime, our local weather guy likes to mention the temps n Truckee, California. I will tackle the job this coming week. Thanks for the advice.
Old 08-07-2016, 03:27 PM
raerjim's Avatar
raerjim
raerjim is offline
Update: Pulled the T bars with the t.ruck on jack stands. No big deal. Removing the clamshell which holds the bushings in place was another matter, as they have 2 large industrial strength tack welds that have to be dealt with (chisel + cutoff wheel) without damaging the "clamshell" bushing retainer. Anyhow, I got the job done. Inner and out bushings replaced and lubed. The truck, which was twitchy and darty has settled right down. I would rate it 75% improved. Hopefully this week an alignment will fix all my troubles. BTW, the original rubber bushings (outer) were obliterated and I had torsion bar go metal to metal with the lower control arm. Thanks for the assist. Jim
Old 08-07-2016, 09:47 PM
truckeemtnfords
Jim, did you go with the polyurethane bushings because when I did mine I used Moog replacement rubber bushing. I would consider upgrading to polyurethane. Thanks
Old 08-08-2016, 01:31 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Good news Jim!
Old 08-08-2016, 10:38 AM
raerjim's Avatar
raerjim
raerjim is offline
Originally Posted by CharlieLed
Good news Jim!
REALLY HAPPY!
Old 08-08-2016, 10:47 AM
raerjim's Avatar
raerjim
raerjim is offline
Dave, Yes I did go with Johnny @ Polybushings.com. When I first discovered that my bushings were pretty much gone, I looked on Amazon and found some NOS rubber bushings for 155$ for just the 2 outers. No steel parts. Thanks to a search of FTE, I found a member who documented his bushing swap on here. ( I forget who it was. You know who You are. Thank You) He had Polybushing.com's URL and i got all 4 bushings and a tube of lube for 125$ Have a great week.
Old 08-08-2016, 12:03 PM
truckeemtnfords
Thanks, glad it worked out easy for you.
TheNuge
1999 to 2016 Super Duty
08-27-2011 03:25 PM
afonda
19
02-04-2009 01:03 PM
rugermack
05-12-2008 12:49 PM
holstein05
04-22-2008 05:37 PM
Hoop
06-24-2004 08:54 PM
Quick Reply: Volare torsion bar bushings
